Shibaura (1720,1920,2120) Valve Adjustment
   / Shibaura (1720,1920,2120) Valve Adjustment #1
F0RD1720
Ford 1720
I am trying to adjust valves on a Shibaura engine. The procedure requires an alignment of the the top mark on the crank pulley with the top mark of the timing gear case. The top mark on the gear case is very clear. I can't find the crank pulley mark. Would anyone know what I should be looking for? Paint mark, line, or some other alignment indicator?
   / Shibaura (1720,1920,2120) Valve Adjustment #2
Welcome and don’t sweat the marks. Turn the crank by hand and watch the valves open (rocker down) on the first valve, then close. Turn the crank a little further. At this point, that valve along with 3 others will be closed and the rockers loose. Set the gap on them paying attention to which is intake or exhaust.
Next turn the crank 180 degrees and adjust the other 3.
   / Shibaura (1720,1920,2120) Valve Adjustment #3
Tractor Tech is correct. Easiest way to do it.
Thank you
2016 Ford F-250 Ext. Cab Pickup Truck (A53422)
2016 Ford F-250...
Year: 2012 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 61,276 Plate: Body Type: 4 (A50324)
Year: 2012 Make...
2020 EAST TEXAS TRAILER STEAMER TRAILER (A53843)
2020 EAST TEXAS...
2012 JOHN DEERE 13-INCH REAR WHEEL SPACER FOR 10 BOLT HUB (A55301)
2012 JOHN DEERE...
PALLET OF SCAFFOLDING (APPROX. 18 PC) (A52706)
PALLET OF...
VERMEER NAVIGATOR 53 D23X30111 DRILL (A51406)
VERMEER NAVIGATOR...
