Shibaura (1720,1920,2120) Valve Adjustment
   / Shibaura (1720,1920,2120) Valve Adjustment #1
F0RD1720
Ford 1720
I am trying to adjust valves on a Shibaura engine. The procedure requires an alignment of the the top mark on the crank pulley with the top mark of the timing gear case. The top mark on the gear case is very clear. I can't find the crank pulley mark. Would anyone know what I should be looking for? Paint mark, line, or some other alignment indicator?
   / Shibaura (1720,1920,2120) Valve Adjustment #2
Welcome and don’t sweat the marks. Turn the crank by hand and watch the valves open (rocker down) on the first valve, then close. Turn the crank a little further. At this point, that valve along with 3 others will be closed and the rockers loose. Set the gap on them paying attention to which is intake or exhaust.
Next turn the crank 180 degrees and adjust the other 3.
   / Shibaura (1720,1920,2120) Valve Adjustment #3
Tractor Tech is correct. Easiest way to do it.
Thank you
Takeuchi Skid Steer (A52377)
Takeuchi Skid...
2008 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2008 DRAGON 150...
TEST BID LOT (A50775)
Lincoln Electric 225 Ranger Welder Generator (A52377)
Lincoln Electric...
2012 Volkswagen Jetta Sedan (A53424)
2012 Volkswagen...
2015 SkyJack SJ86T 4x4 86ft Telescopic Boom Lift (A52377)
2015 SkyJack SJ86T...
