shenniu
/ shenniu #1
wentzclan5
logan oh
shenniu 25
my tractor runs for short while and than dies any ideas also my pto can only be pulled up to activate if tractor is off grinds and wont go in while running
/ shenniu #2
To troubleshoot the stalling issue, check the fuel path for clogged filters/screens. There's likely one in the tank, one in the sediment bowl, one or more in the banjo fittings.
PTO problem can likely be fixed with a clutch release adjustment.
//greg//
/ shenniu #3
Greg is right about checking the fuel path. It will involve removing the entire sediment bowl assembly from the tank. There is usually a screen on Chinese tractors up in there where it screws into the bottom of the tank. Also screens hidden in the fuel hoses through out. Remove them all and clean. Once reinstalled you must bleed the system. I would also replace the spin on fuel filter at this time if you have one.
As for the pto make sure you have the clutch in and let everything spin down. If you have a implement like a bush hog this can late 60 seconds or so.
Chris
2014 Nissan Quest Van (A61574)
2014 Nissan Quest...
KUBOTA SVL97-2 SKID STEER (A62129)
KUBOTA SVL97-2...
Unverferth 632 (A64119)
Unverferth 632...
(INOP) 2018 BOMAG BMP8500 TRENCH COMPACTOR (A60429)
(INOP) 2018 BOMAG...
LOOK! (A63109)
LOOK! (A63109)
Root Rake Loader Attachment (A59228)
Root Rake Loader...
