shenniu
/ shenniu #1
wentzclan5
logan oh
shenniu 25
my tractor runs for short while and than dies any ideas also my pto can only be pulled up to activate if tractor is off grinds and wont go in while running
/ shenniu #2
To troubleshoot the stalling issue, check the fuel path for clogged filters/screens. There's likely one in the tank, one in the sediment bowl, one or more in the banjo fittings.
PTO problem can likely be fixed with a clutch release adjustment.
//greg//
/ shenniu #3
Greg is right about checking the fuel path. It will involve removing the entire sediment bowl assembly from the tank. There is usually a screen on Chinese tractors up in there where it screws into the bottom of the tank. Also screens hidden in the fuel hoses through out. Remove them all and clean. Once reinstalled you must bleed the system. I would also replace the spin on fuel filter at this time if you have one.
As for the pto make sure you have the clutch in and let everything spin down. If you have a implement like a bush hog this can late 60 seconds or so.
Chris
2022 EZ-GO ELITE...
2013 FORD F750 XLT SD SERVICE CRANE TRUCK (A62613)
2013 FORD F750 XLT...
1975 Bomag MPH1 Soil Reclaimer Mixer (A61572)
1975 Bomag MPH1...
2016 International Workstar 7500 T/A Dump Truck (A61573)
2016 International...
2015 Ford F-350 4x4 Ext. Cab Pickup Truck (A61573)
2015 Ford F-350...
2017 Caterpillar 349FL Hydraulic Excavator (A61572)
2017 Caterpillar...
