Shenniu tractor headbolt torque?
   / Shenniu tractor headbolt torque? #1
oldsmoman69
Mineral, VA
Shenniu 254, MF 1533, Case 224, Dixie Chopper ZT
Could anyone tell me the torque sequence for the headbolts for a Shenniu SN254 tractor? A diagram would be greatly appreciated. I was thinking of re-torqueing these as I am checking the valve lash. I have read that it is important to check the torque on these bolts.
   / Shenniu tractor headbolt torque? #2
Which engine?
//greg//
The model that is listed in the operators book says it is a model 295T. It is a two cylinder. Made by Hubei engine works. 95mm bore and 115mm stroke.
   / Shenniu tractor headbolt torque? #4
Something like this
//greg//
That type of diagram is exactly what I am looking for. But that appears to be for a different engine than what I have.
   / Shenniu tractor headbolt torque? #6
Coming up with a perfect diagram for a odd ball tractor may be tough. What Greg gave you gives you the jist of how to do it. You may have to wing it a little. Remember, its a Chinese tractor, not a 747. Take your time, keep things clean, use educated guesses, and you will be fine.
Chris
   / Shenniu tractor headbolt torque? #7
A two cylinder is a two cylinder. Six head bolts. Even though the diagram is not an exact match to your head, the torque sequence is the same
//greg//
   / Shenniu tractor headbolt torque? #8
what is the headboly torque setting(how much pounds) and what is the value gap setting?
   / Shenniu tractor headbolt torque? #9
What is the head bolt torque and the valve lash for a shenniu 254 with engine number HB295T? Need answer as soon as possible please..
   / Shenniu tractor headbolt torque? #10
NEW HOLLAND 706 30 INCH 3PT DIRT SCOOP (A52748)
NEW HOLLAND 706 30...
2015 MACK ELITE LEU633 GARBAGE TRUCK (A51406)
2015 MACK ELITE...
Guard Rail Joints (A51692)
Guard Rail Joints...
2008 Wells Cargo T/A Enclosed CERT Trailer (A50324)
2008 Wells Cargo...
2012 Chevrolet Captiva Sport SUV (A50324)
2012 Chevrolet...
