Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #11
Use 5W -40. And you're covered from Canadian cold to Southern heat. All year long.
   / Shell Rotella T4 SAE 10W-30 ALERT! #12
I use Rotella T6 in all 4 of my tractors. Very good oil.
   / Shell Rotella T4 SAE 10W-30 ALERT! #13
Still a struggle for me to find T6 in 5w40. Seems 90% of the blue jug T6 I see anymore is 15w40.
Was just at walmart last night.....they had 2 2.5gal jugs of 15w40 T6, And about a dozen 1 gal jugs. But only TWO 1-gal jugs if the 5w40 T6 :mad:
   / Shell Rotella T4 SAE 10W-30 ALERT! #14
The supply seems tight on the T6 5W-40 for quite some time now. It started with the little bug a few years ago.
My son works at a truck repair shop. That's the most used oil on their floor.
At some point they had to delay oil services due to shortage.
   / Shell Rotella T4 SAE 10W-30 ALERT! #15
If you cant find T6 5w-40 at Walmart check TSC. They usually have it because they are a lot higher but they will price match.
   / Shell Rotella T4 SAE 10W-30 ALERT! #16
We have both a TSC and a Rural king that I frequent. And usually one of them will have some also. But they are always similar in price to walmart...Somewhere around $25-$26 for a gallon and ~$60-$65 if you can find it in 2.5gal
   / Shell Rotella T4 SAE 10W-30 ALERT! #17
Local Walmart has 1 gal for $23.48 and I can order 2.5 gal for store pickup or home delivery for $55.
Local TSC has 1 gal for $29.99 and 2.5 gal for $69.99.
May pick up a couple of 2.5s while they are at this price.
2019 UniCarrier 5k Propane Forklift (A56857)
2019 UniCarrier 5k...
2025 Yakta YXR610 Zero Turn Lawnmower (A57453)
2025 Yakta YXR610...
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
1969 Lincoln Continental Mark III (A56857)
1969 Lincoln...
2018 FREIGHTLINER M2 26FT NON CDL BOX TRUCK (A59575)
2018 FREIGHTLINER...
Kubota L2800 (A57148)
