Shell Rotella T4 SAE 10W-30 ALERT!
   / Shell Rotella T4 SAE 10W-30 ALERT! #11
Use 5W -40. And you're covered from Canadian cold to Southern heat. All year long.
   / Shell Rotella T4 SAE 10W-30 ALERT! #12
I use Rotella T6 in all 4 of my tractors. Very good oil.
   / Shell Rotella T4 SAE 10W-30 ALERT! #13
Still a struggle for me to find T6 in 5w40. Seems 90% of the blue jug T6 I see anymore is 15w40.
Was just at walmart last night.....they had 2 2.5gal jugs of 15w40 T6, And about a dozen 1 gal jugs. But only TWO 1-gal jugs if the 5w40 T6 :mad:
   / Shell Rotella T4 SAE 10W-30 ALERT! #14
The supply seems tight on the T6 5W-40 for quite some time now. It started with the little bug a few years ago.
My son works at a truck repair shop. That's the most used oil on their floor.
At some point they had to delay oil services due to shortage.
   / Shell Rotella T4 SAE 10W-30 ALERT! #15
If you cant find T6 5w-40 at Walmart check TSC. They usually have it because they are a lot higher but they will price match.
   / Shell Rotella T4 SAE 10W-30 ALERT! #16
We have both a TSC and a Rural king that I frequent. And usually one of them will have some also. But they are always similar in price to walmart...Somewhere around $25-$26 for a gallon and ~$60-$65 if you can find it in 2.5gal
   / Shell Rotella T4 SAE 10W-30 ALERT! #17
Local Walmart has 1 gal for $23.48 and I can order 2.5 gal for store pickup or home delivery for $55.
Local TSC has 1 gal for $29.99 and 2.5 gal for $69.99.
May pick up a couple of 2.5s while they are at this price.
2008 Featherlite Trailer, VIN # 4FGE853218C108480 (A53424)
2008 Featherlite...
377789 (A51573)
377789 (A51573)
2006 FORD F-350 (A53422)
2006 FORD F-350...
2016 Ford F-450 Pickup Truck (A51692)
2016 Ford F-450...
2015 Ram 3500 4x4 Crew Cab Pickup Truck (A53422)
2015 Ram 3500 4x4...
2011 John Deere Tractor (A55973)
2011 John Deere...
