Sheet metal brake
/ Sheet metal brake #1
handirifle
Central Coast of CA
Massey Ferguson 1010
I'm thinking of using some scrap angle iron I have to make a sheet metal brake. Has anyone done this before?
/ Sheet metal brake #2
Yep,
10 footer and it didn't work except on short pieces. The 1/4 x 3 " angle iron flexed to much. Bent on the ends opened up in the middle.
/ Sheet metal brake
Interesting. I was thinking of welding a length of solid steel rod, about 1" dia, along the entire length, and using that as the pivot point at either end, as well.
Was yours supported like that, or unsupported? Curious. I can definately see the angle flexing on it's own.
/ Sheet metal brake #4
No it wasn't supported and that might help. It's still out there bolted to a bench but the stuff I needed bent, I needed right then, so it got abandoned and no use for it since.
/ Sheet metal brake #6
I made a 26" brake from 1/4" x 3" angle. It was supported on top by a 1"square tube brace. I ran hex bolts down through the brace to clamp the steel firmly along the length of the brake. It's a bit cumbersome to use a hex key to secure the brake before bending, but for the few pices I bend it works fine.
/ Sheet metal brake #8
/ Sheet metal brake #9
The better idea for that 1" rod is to bend it to form two legs of a triangle with the angle iron as the third leg. Then weld in a section vertically in the middle that allows you to put tension on the angle iron( something like threaded rod/coupler). This put the two rod legs in tension and presses down on the center of the angle iron to keep it from flexing. Maybe somebody good with drawings can illustrate for me?
/ Sheet metal brake
Thanks for the extra info. The HF brake is too expensive, for me. I only need it on rare occasions, and the local shops have a $40-45 min charge. I can build one, I think for just a few bucks that will do what I need.
I searched the web and did see a few that were braced as you mention, moeh1, so maybe that will be easier. Wondering if there's a easy way to insure the brake pivots in the right place?
/ Sheet metal brake #11
Yeah, pivot point is the key. I looked at some online plans, but it looked like I could buy a cheap brake for what the stuff might cost. The simplest way I've seen to get the pivot right is to cut out a small section at each end of both angle irons to provide clearance for a set of pivot sleeves, clamp the two angle irons together, drop in two pivot sleeves with a pin in them and weld the sleeves in place (one to each angle iron). Hope that makes sense?
/ Sheet metal brake #13
Thats what I was trying to describe! When you cut the slots, you are trying to remove enough material to get the center of the pin right where the two angle iron corners meet. Have fun.
/ Sheet metal brake
Well I will still build a brake, but for now, I ran across a local trailer shop that had the fenders I needed, for $15 each. Kinda makes it hard to justify building the brake for that.
/ Sheet metal brake #15
I got lucky and picked up a 4' Chicago brake for only $200.:D Look for a shop closing down or auctions. They are heavy and can take up some room, mine is about 5 1/2 ' long x 2' deep x 41/2' high @3-400lbs? on wheels to get out of the way when not using. If you try to build one think lots of iron!! Big hinges and bracing for bender and the clamp that holds the sheetmetal down and something solid to mount it on. A lot of force is created when folding even thin sheetmetal and handles on both sides is a plus.:thumbsup:
UNVERFERTH HT25 HEADER CART (A63291)
UNVERFERTH HT25...
2007 Sterling L7500 Terex Commander C6060 T/A Insulated Derrick Digger Truck (A60460)
2007 Sterling...
2023 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A61573)
2023 Chevrolet...
2008 Ford F-250 Ext. Cab Pickup Truck (A61573)
2008 Ford F-250...
2023 Freightliner Cascadia 116 S/A Day Cab Truck Tractor (A61573)
2023 Freightliner...
2020 INTERNATIONAL LT625 48" SLEEPER (A62613)
2020 INTERNATIONAL...
