Shear Pins source
/ Shear Pins source #1
fyrewil
Fallon NV
Mahindra 2015 HST
Is there a place to get shear pins in quanity, from what I have read so far, I will need to have a supply before I start my (Wifes) fence project.
I ordered a Gearmore D20 for my Mahindra 2015 HST today.
Thanks for info in advance
Willie:D
/ Shear Pins source #2
My local feed/farm store has bins of all different types and sizes of pins.
/ Shear Pins source #3
If you have a TSC close by they sell bolts in bulk. Just make sure you get the right grade. Some use Grade 5 and some grade 2. I think mine are 5/16x3 1/2 grade5.
/ Shear Pins source #4
Most shear pins are just regular bolts, like said in previous post check size and grade. Any hardware store should be able to help you out.
/ Shear Pins source
Learn something new each and every day.... Thank you all for your quick repsonse back.:D
I will check it out tomorrow.
Hopefully Big R or ACE will have.... Otherwise local tractor dealership
Thanks again
Willie:D
/ Shear Pins source #7
Just some bolt info. SAE Hex bolts have a basic grade as grade 2 and no marks on the head. The grade is stamped as 2 + number of lines on the head. 3 lines equal a grade 5. 5 lines equal grade 8.
/ Shear Pins source
Thank you, after reading the post lastnight about common grade 2, I went and looked up "grading bolts".
Now waiting on unit to get here to detirmine what size I am going to need to buy.
Thanks for all of the quick replies
Willie
/ Shear Pins source #11
OK, I was testing you to see if you were really reading the post. I used my calculator and yes 5 + 2 = 7. I guess that should be 6 lines on the head.
New/Unused 72in No Till Seed Drill (A65583)
New/Unused 72in No...
2022 John Deere 5055E (A64126)
2022 John Deere...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
New/Unused Mini Quick Attach Pallet Forks (A65583)
New/Unused Mini...
2021 Spapperi 3pt 2 Row Transplanter (A64126)
2021 Spapperi 3pt...
2 Bottom Plow (A62613)
