Shear Pins source
/ Shear Pins source #1
fyrewil
Fallon NV
Mahindra 2015 HST
Is there a place to get shear pins in quanity, from what I have read so far, I will need to have a supply before I start my (Wifes) fence project.
I ordered a Gearmore D20 for my Mahindra 2015 HST today.
Thanks for info in advance
Willie:D
/ Shear Pins source #2
My local feed/farm store has bins of all different types and sizes of pins.
/ Shear Pins source #3
If you have a TSC close by they sell bolts in bulk. Just make sure you get the right grade. Some use Grade 5 and some grade 2. I think mine are 5/16x3 1/2 grade5.
/ Shear Pins source #4
Most shear pins are just regular bolts, like said in previous post check size and grade. Any hardware store should be able to help you out.
/ Shear Pins source
Learn something new each and every day.... Thank you all for your quick repsonse back.:D
I will check it out tomorrow.
Hopefully Big R or ACE will have.... Otherwise local tractor dealership
Thanks again
Willie:D
/ Shear Pins source #7
Just some bolt info. SAE Hex bolts have a basic grade as grade 2 and no marks on the head. The grade is stamped as 2 + number of lines on the head. 3 lines equal a grade 5. 5 lines equal grade 8.
/ Shear Pins source
Thank you, after reading the post lastnight about common grade 2, I went and looked up "grading bolts".
Now waiting on unit to get here to detirmine what size I am going to need to buy.
Thanks for all of the quick replies
Willie
/ Shear Pins source #11
OK, I was testing you to see if you were really reading the post. I used my calculator and yes 5 + 2 = 7. I guess that should be 6 lines on the head.
2000 FREIGHTLINER CENTURY CLASS 6X4 T/A SLEEPER TRUCK TRACTOR (A59914)
2000 FREIGHTLINER...
Coleman Powermate Generator (A62613)
Coleman Powermate...
AGT Industrial YSRT14 (A64127)
AGT Industrial...
(16) Kinze 60 Cell Bean Plates (A65640)
(16) Kinze 60 Cell...
Anvil (A64127)
Anvil (A64127)
2016 Peterbilt 579 Automatic High Top Sleeper (69") (A62613)
2016 Peterbilt 579...
