Shear Pin Shocker
   / Shear Pin Shocker #31
This seems to be a case where proprietary setups cost everyone more in the long run. Why can't they standardize a system for something as simple as shear pins?
By the way, I have seen this setup on many applications where they not only hit you for $ at the beginning, but every time something as simple as a shear pin snaps, they gouge you again! Very agrivating....
   / Shear Pin Shocker #32
Why not drill it out to 3/8 and use 3/8 all-thread, this has a minor diameter of 5/16 which would be a little easier to shear.
Bolt houses sell 3,6,12' lengths and 6' is than 1 shear pin.
   / Shear Pin Shocker #33
<font color="blue"> Henro.. I was wondering.. w/ the slipclutch.. how many shearbolts have you gone through? </font>
Maybe someone with more holes under thier beit and a slip clutch on thier post hole digger can chime in here. I don't have enough holes dug to really know how well the slip clutch actually works. I got it because my neighbor recommended that I get one.
Only dug about ten or twelve holes with mine so far...
Anyone out there have some real experience with a slip clutch on a phd? Worth it? I guess it is but ... but that is just opinion really. We some experience to do the talking /forums/images/graemlins/smile.gif
   / Shear Pin Shocker #34
i have a low end phd but I can use cheap grade two bolts with lock nuts, Takes about 30 seconds to swap when they shear and they cost around 30 cents each. If I had to pay $8 I'd have one hell of a lot of $50 post holes!!!!!! I wouldn't even think twice about getting a slip clutch. You can get them for about $100 and at $8 each it'll pay for itself pretty quickly, especially if you have rocky ground. I just did 5 holes for an addition on my land. Took me 5 hours and handdigging. Did 8 holes for a friend and it took about 25 minutes for all of them. He didn't have a rock bigger than an apple on his land!! My luck I have a rock farm.................
   / Shear Pin Shocker #35
An update with a little more information. As I had said earlier, my PHD2101 came with a 3/8" grade-5 bolt in the shear bolt hole. I verified with the dealer that the person setting it up had not drilled out one side of the yoke. So I sent a note to Bush Hog via their web site. I got a call from BH tech support in Selma, AL the next day. Henry, the BH rep, was very helpful. He confirmed what Jerry has been saying: the PTO shaft supplied won't stand up to the double shear (both sides in shear at once) of a full 3/8" bolt, even grade-2. That is the reason for the stepped pin. The PTO shaft is a model T10 (Comer brand I believe, as least the manual that came with the unit that discussed the PTO shaft was from Comer, who supplies the gearbox). He told me to have my dealer order a replacement shaft assy and send the warranty claim to his attention. He suspects that the supplier had put the wrong/bad yoke on mine. Excellent customer support.
As an aside, I've used my 2101 with an 18" auger (BH only specs the 2101 for up to a 9" auger) to drill nine 48" deep holes. Granted the dirt was soft and I didn't hit very many rocks, but I have not sheared any of the stepped shear pins.
Hope this helps,
Kevin
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2017 PETERBILT 579 (A53843)
2017 PETERBILT 579...
(6) 2000 LB TRAILER JACKS (A57192)
(6) 2000 LB...
2013 JOHN DEERE 27D EXCAVATOR (A52707)
2013 JOHN DEERE...
2020 CATERPILLAR 259D3 SKID STEER (A52705)
2020 CATERPILLAR...
2015 Ford Transit 150 Cargo Van (A55852)
2015 Ford Transit...
