Shear Pin Shocker
   / Shear Pin Shocker #21
<font color="blue">(...$8 or $6 per shear pin ...) </font>
Hey Bill...
You're not using that broken calculator again... Are ya? /forums/images/graemlins/wink.gif
   / Shear Pin Shocker #22
<font color="blue"> You're not using that broken calculator again... Are ya? </font>
Nope! Just repeating what was reported above in this thread. I can't comprehend it, but I don't doubt what the guys are reporting... /forums/images/graemlins/frown.gif
The CHEAP ones were $5.50 each...amazing...
   / Shear Pin Shocker #23
The Bush Hog model 2101 uses the same gear box as the model 2102, but the 2101 uses a lighter duty pto shaft. This is the reason that the 2101 uses a pin without a head that has a 3/8" shaft and is necked down on the threads to 5/16". Bush Hog <font color="red">does not</font> recommend the threads on the yoke be drilled out and the pin replaced with a 3/8" bolt because of the lighter duty pto shaft. Bush Hog will not warranty the pto shaft if the pin is replaced with a bolt.
   / Shear Pin Shocker #24
/forums/images/graemlins/laugh.gif
<font color="blue">(...Grade two bolts go for $1.19 per lb ...)</font>
Hi Bill...
I had quickly seen this and forgot about the rest of the thread... /forums/images/graemlins/blush.gif
   / Shear Pin Shocker #25
<font color="blue">(...has a 3/8" shaft and is necked down on the threads to 5/16"....) </font>
What part of the bolt is in the "shear" area?
Without physically seeing it... off the cuff, why couldn't you use a standard Grade 2 - 5/16" bolt? (without drilling it out)
   / Shear Pin Shocker #26
John,
One side of the yoke is drilled 3/8" and the thread side of the yoke is 5/16". The pins shears at 3/8" on one side and shears at 5/16" on the other side. According to BH the combined shear of 5/16 and 3/8 is the required amount for that pto shaft. A total shear of both sides at 3/8 would be to much for that shaft. If you just put a 5/16" grade 2 bolt in, then the 5/16 would only be tight on the threaded portion thus the input shaft would have slop on the yoke all the time.
   / Shear Pin Shocker #27
I understand the taper you're saying, but won't the "nut" keep the tension on the 5/16" bolt... thereby attenuating any "slop"?
   / Shear Pin Shocker #28
All of the un-threaded portion would be slop.
   / Shear Pin Shocker #29
At $6 to $ 8 a pop, you'd think a slip clutch could be payed for inside a week. /forums/images/graemlins/smirk.gif
   / Shear Pin Shocker #30
"I got the slip clutch anyway"
Henro.. I was wondering.. w/ the slipclutch.. how many shearbolts have you gone through?
I can't believe $8 a pop.. w/ that price I know one post hole that would have cost me almost $50 to dig.. lot's of roots.
2023 54' Hooklift Dumpster 15 Cubic Yard (A53422)
2023 54' Hooklift...
UNUSED FUTURE HYD MINI THUMB CLIP (A57193)
UNUSED FUTURE HYD...
2016 Case 821F Articulated Wheel Loader (A55851)
2016 Case 821F...
PALLET OF NYLON SLINGS, METAL TOOLBOX W/ CHAINS (A54757)
PALLET OF NYLON...
2007 JOHN DEERE 710J BACKHOE (A52707)
2007 JOHN DEERE...
Horse Statue (A55853)
