Shear Pin for brush hog
/ Shear Pin for brush hog #1
Dirtball
Eastern, Pa.
NH TC33D
Is there a symbol ot letters on the head of a shear pin. Or do we just use grade 3 or lesser junk hardware.. It's a 60 in. HD rotary brush cutter. oh and anyone have a tip to re-assemble the collar over the grease fitting on the end of a pto shaft? it's a plastic inner ring that snaps? into the outer ring somehow and possibly turns to twist lock? Italian made generic brush cutter......thanks
/ Shear Pin for brush hog #2
Most 60" and 72" I've seen call for an 8mm grade 8.8 bolt (I think by 50mm length, but measure). The smaller hogs call for an SAE grade 2.
/ Shear Pin for brush hog #3
If in doubt about the proper shear pin to use, default to the lowest grade available and size the bolt to fit the bore perfectly.
My rotary cutter uses a grade 2 bolt..
Soundguy
/ Shear Pin for brush hog #4
Most likely a grade 2 bolt. You want the shear bolt to be the weakest link, so that it snaps before anything else does!
-Brad
2013 Komatsu WA320 Wheel Loader (A60352)
2013 Komatsu WA320...
2022 Mack Anthem T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Mack Anthem...
2008 BMW 3 series Passenger Car, VIN # WBAWB33568P132774 (A65563)
2008 BMW 3 series...
Horse Trailer (A62613)
Lonestar Panel 24ft. Free Standing Panel with 7ft. Gate (A65640)
Lonestar Panel...
2021 John Deere RS72 Skid Steer Rotary Cutter (A65640)
2021 John Deere...
