Shear Pin for brush hog
/ Shear Pin for brush hog #1
Dirtball
Eastern, Pa.
NH TC33D
Is there a symbol ot letters on the head of a shear pin. Or do we just use grade 3 or lesser junk hardware.. It's a 60 in. HD rotary brush cutter. oh and anyone have a tip to re-assemble the collar over the grease fitting on the end of a pto shaft? it's a plastic inner ring that snaps? into the outer ring somehow and possibly turns to twist lock? Italian made generic brush cutter......thanks
/ Shear Pin for brush hog #2
Most 60" and 72" I've seen call for an 8mm grade 8.8 bolt (I think by 50mm length, but measure). The smaller hogs call for an SAE grade 2.
/ Shear Pin for brush hog #3
If in doubt about the proper shear pin to use, default to the lowest grade available and size the bolt to fit the bore perfectly.
My rotary cutter uses a grade 2 bolt..
Soundguy
/ Shear Pin for brush hog #4
Most likely a grade 2 bolt. You want the shear bolt to be the weakest link, so that it snaps before anything else does!
-Brad
2021 Redirective Crash Cushion Guardrail (A64556)
2021 Redirective...
2014 Kia Sorento SUV (A64557)
2014 Kia Sorento...
2015 KENWORTH T880 KILL TRUCK (A65643)
2015 KENWORTH T880...
2019 ROCK SOLID CARGO 14 T/A SHOWER TRAILER (A65643)
2019 ROCK SOLID...
2014 CASE CX160C EXCAVATOR (A65053)
2014 CASE CX160C...
EZ - Trail 672 Header Trailer (A66285)
EZ - Trail 672...
