Shear Bolts??
/ Shear Bolts?? #1
Avenger
North Idaho
LS XR4145C
I recently purchased a snow blower. Last night I broke my first shear bolt. Fortunately, the manufacture sent a few extras. However, in trying to find replacements, I am coming up empty. Contacting the dealer of the blower has resulted in crickets, and the manufacture doesn't have a parts section on their website.
I need M10x55 cl 8.8 bolts. As many as I can get.
I would typically install a slip clutch on this implement, but I dont think it would work in this situation. Not to mention the lack of space for one.
Any help is greatly appreciated.
/ Shear Bolts?? #2
Just get something that will work. Example we use cut up livestock panel for shear bolts in the post hole auger.
/ Shear Bolts?? #4
Call any bolt supply co. They ship
Grade 2 bolt would do, whatever will fit the hole.
/ Shear Bolts??
I thought shear bolts were supposed to be grade 2?
Grade 5? Thats easy!
/ Shear Bolts?? #7
Elgin Fastener Group Products | Metric Bolt Conversion Data | Specialty  Fasteners
/ Shear Bolts?? #9
Not so.
Grade 2 will just tear and elongate their hole.
You want a shear bolt to snap off clean.
Sometimes they have grooves cut in them to break in the right place.
Good Luck,and try to identify the OEM bolts to see if they are special.
/ Shear Bolts?? #10
A few extra shear bolts also came along with my new blower last year, fortunately so far I have never sheared a bolt.
/ Shear Bolts?? #11
Ten mm diameter (a shade over 3/8") sounds large to me; my snowblowers spec 6mm and 1/4". A 6mm diameter hex bolt takes a 10mm wrench; a 10 mm diameter takes a 17mm wrench. I would measure one of your spares (or the original if you still have it) before ordering.
/ Shear Bolts?? #12
Buy some metric bolts that will fit at your local Harbor Freight. Guarantee they will be Chinesium quality if they're like Princess Auto here.
/ Shear Bolts??
Thank you for all the responses. I heard back from the dealer. They confirmed that a grade 5 bolt found at any hardware store will work just fine. Thats good to know.
And yes, it is 10mm by about 2 inches. Its on a PTO shaft for a 7ft wide blower.
/ Shear Bolts?? #16
Ruffdog inquired about a linked e-bay offering.
Likely Chineesium, ungraded, no locknut. I had checked Bolt Depots pages to confirm the distance across the flats before posting #11. FWIW Bolt Depot prices for M10-1.5 x 55 mm grade 8.8 hex bolts. I have no affiliation with Bolt Depot except as a satisfied customer.
Prod. #LengthEach priceBag priceBulk price
624455mm$0.73 / ea$25.84 / 50$220.00 / 500
Metric hex nylon insert lock nuts, Zinc plated class 8.8 steel, 10mm x 1.5mm
$0.22 / ea
$12.40 / 100$102.00 / 1000
/ Shear Bolts?? #17
Mine seem to measure 5/16 x 2” and take either a 13mm or 1/2 inch wrench. There is some markings on the head of the bolts that looks like maybe YLZ 68 but I’m not sure what that’s supposed to mean , since my blower was built in Canada I’m guessing the shear pin is metric with self locking nut. since the blower is one year old never sheared a pin and came with 5 spare pins I most likely won’t be rushing out to buy more.
/ Shear Bolts?? #18
^^5/16 is VERY close to the same diameter as 8mm.
/ Shear Bolts?? #20
. . . There is some markings on the head of the bolts that looks like maybe YLZ 68 but I’m not sure what that’s supposed to mean . . .
SAE or inch bolts have hash marks to indicate grade; metric bolts have arabic numerals to indicate class. A web search will turn up charts of the various markings and the equivalence of grade and class. As I understand it, the alpha-numeric characters on bolt heads are a code so the manufacturers, distributors, vendors, and others who are privy to the codes (like the check-out clerk at a box store) can identify the bolts without calipers and thread gauges.
2013 International WorkStar 7400 4x4 Altec AM650 50ft Material Handling Insulated Bucket Truck (A59230)
2013 International...
CATERPILLAR 631E SERIES II MOTOR SCRAPER (A62129)
CATERPILLAR 631E...
2022 Peterbilt 567 T/A Wet Kit Day Cab Truck Tractor (A61568)
2022 Peterbilt 567...
2020 Global R3 Air Street Sweeper (A56857)
2020 Global R3 Air...
Case 1020 25ft Draper Head (A63118)
Case 1020 25ft...
INOP/NON-RUNNING 2000 Sterling L7500 Series Dump Truck, VIN # 2FZHAFBC2YAH48068 (A61165)
INOP/NON-RUNNING...
