Shear Bolts, What do you Use?
/ Shear Bolts, What do you Use?
I am a big chicken when it comes to tearing up things, I will have both, shear pin and relief valve.
Everything I make is overkill and does last real good
Jim
/ Shear Bolts, What do you Use? #22
That sounds like a good plan.
Soundguy
/ Shear Bolts, What do you Use? #23
Soundguy,
That is pretty much what I told him via telephone. Thanks for chiming in.
I think he ought to go with a clutch on the drive shaft plus the shear pin, but I can't say too much cause I have not taken the time to add a clutch to my drive line, and I have it out in the garage just waiting on me. (Probably waiting on me to break something and then I will close the doors after the cows got out.)
David from jax
/ Shear Bolts, What do you Use? #24
scesnick said:
I know this isn't about snow blowers but that is what I have a major problem with shear bolts with. It is a Ber-Vac 64" and when I run grade 2 pins they sheer pretty much as soon as I start blowing snow. I up graded to grade 5's and even they will shear when I hit clumps of semi frozen snow. I don't want to even try grade 7's but I get sick of carrying a pocketful every time it snows. Any ideas???
If they are the shear bolts that attach the blades to the axle, you need to have a spacer on there that goes from the round axle to the flat bolt head and nut. Otherwise, they break really easily. Mine does the same thing if I don't have the spacers on them. Problem is, it's really hard to find them.
2014 Freightliner 105' Bucket Truck (A63689)
2014 Freightliner...
2001 International 4000 DT 466E (A60462)
2001 International...
2017 Ford Explorer AWD SUV (A61569)
2017 Ford Explorer...
John Deere R4023 (A64126)
John Deere R4023...
1992 GMC Top Kick Fuel Truck (A62679)
1992 GMC Top Kick...
2021 KOBOTA SVL97-2 SKID STEER (A65053)
2021 KOBOTA...
