smfcpacfp
Veteran Member
- Joined
- Nov 21, 2007
- Messages
- 1,314
- Tractor
- Kubota B3030HSDC
The local dealer wants $1 each for the shear bolt Nut and washer) for this unit. Does anyone know where they can be had cheaper?
I went to get a couple makeshift shear bolts at Tractor Supply Co on a weekend when my dealer was closed & when I grabbed some low grade bolts, the clerk there told me that I had it backwards - that low grade would "give" and flex rather than break when it should and said I needed grade 5 or 8 that - being more rigid & inflexible - would snap when they should. Can someone clear this up for me?
My front mounted snow blower on my Kubota 2350 calls for grade 8 in the rear rotor, and grade 5 in the augers.
No, this is not true....I believe that higher grade bolts are stronger in tension, but not as strong in shear...
