shear bolts B2782 snowblower
   / shear bolts B2782 snowblower #11
I went to get a couple makeshift shear bolts at Tractor Supply Co on a weekend when my dealer was closed & when I grabbed some low grade bolts, the clerk there told me that I had it backwards - that low grade would "give" and flex rather than break when it should and said I needed grade 5 or 8 that - being more rigid & inflexible - would snap when they should. Can someone clear this up for me?
I'm thinking you're right, grade 2 is fine for a shear bolt. Grade 8 is a much stronger bolt, I've never seen them "properly" used in a snowblower.
I'm not saying it's impossible, only unlikely.
Chilly
   / shear bolts B2782 snowblower #12
I have a question...What is the purpose of the groove on the auger shear bolt for the B2782 snowblower?
   / shear bolts B2782 snowblower #13
I suspect the groove is there to create a weak point. Perhaps even a grade 2bolt is too strong for that type of machine. Just a guess though.
   / shear bolts B2782 snowblower #14
I have always been told that grade 8 bolts are better as shear bolts as they are more brittle than lower grade bolts and will shear better. Lower grade bolts have a tendency to bend and stretch rather than break. I believe that higher grade bolts are stronger in tension, but not as strong in shear. The 2782 has 2 different shear bolts, the auger bolts with the groove and the other on the shaft that Kubota specifies as a standard grade 8 bolt. I haven't looked closely at the auger shear bolts from Kubota to see what grade they are. I have used grade 8 bolts as shear bolts on my larger rotary cutter and have had no problem with them, they shear off nicely.
   / shear bolts B2782 snowblower #15
My front mounted snow blower on my Kubota 2350 calls for grade 8 in the rear rotor, and grade 5 in the augers.
   / shear bolts B2782 snowblower #16
They may call for grade 8, but that's probably why they have the "special" groove in them, to create a weaker point???
   / shear bolts B2782 snowblower #18
I have a 900ft driveway and live in west Michigan and use said blower on my B2630 so I think I qualify as having some knowledge on this subject.:D
I can tell you from experience that for the back blower, grade 2 bolts will sheer just with the snow load, grade 5 will last a little longer, and grade 8 is what comes on it and what Kubota sells for replacement and will sheer with wood or dog nylabones.:eek:
   / shear bolts B2782 snowblower #19
Well, whatever the manufacturer calls for should be what goes in them.. quite often we like to second guess them based on our own experiences.
Chilly
   / shear bolts B2782 snowblower #20
I have 2 shear bolts in front of me. #1 has a letter N at the 12:00 position. #2 has letters YHC at the 12:00 and hash marks at the 2:00, 6:00 and 10:00 positions. So reading the previous posts..am I correct that #1 is a grade 2 and #2 is a grade 5? Should I use the grade 5 for the fan or the Grade 2. Thanks.
QT Single Tine Bale Spear (A49339)
QT Single Tine...
2064 (A46502)
2064 (A46502)
Pallet of Assorted Nuts and Bolts (A49339)
Pallet of Assorted...
2018 KENWORTH T680 TANDEM AXLE SLEEPER (A45678)
2018 KENWORTH T680...
Garage Door Panels (A49339)
Garage Door Panels...
2016 John Deere 3038E Front Loader Utility Tractor (A46683)
2016 John Deere...
