Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available?
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Do they make a shear bolt (implement) to 6 spline adapter (driveshaft end) , or a add on slip clutch, shear bolt (implement end) to 6 spline (driveshaft end) ?
I have found one listing for a add on slip clutch for about $100 thats describes itself as what I need but cant get in touch with the guy to verify it before purchasing.
Ive work google out searching for alternates but have found none
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #2
You want to turn your 1 3/8 round shaft on the cutter into a 6 spline 1 3/8?
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #4
I looked at TSC and do not see such a thing. I don't remember ever seeing one like that. If you want it for the over running clutch, that usually goes on the tractor shaft. If you are trying to adapt a double spline pto shaft, it might be easier to just get the right shaft.
Here are some but I havent been able to get pricing. Bare Co USA - Heavy Duty Safety Clutches
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #7
OK. I see what you are trying to do. Most of that style fit shafts that have keyways in them. You can get a pto shaft that has the slip-clutch built in.
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #8
TSC SKU #270109299
New/Unused 7ft 10 Drawer Work Bench (A51573)
New/Unused 7ft 10...
2019 Ford Explorer AWD SUV (A50324)
2019 Ford Explorer...
John Deere 2 Row Corn Head (A50774)
John Deere 2 Row...
JOHN DEERE XUV590M (A53084)
JOHN DEERE XUV590M...
2001 CHEVROLET W4500 12FT FLATBED DUMP (A52141)
2001 CHEVROLET...
40' CONTAINER (A51244)
