Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available?
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #1
Rmart30
Platinum Member
Alabama
Currently have Kubota L4600HST, Kubota M7040, Kubota M8540, two Massey 265's, Massey 230, ...... Had Long 510, Mahindra 3510.Ford 4000, Deere 4230.
Do they make a shear bolt (implement) to 6 spline adapter (driveshaft end) , or a add on slip clutch, shear bolt (implement end) to 6 spline (driveshaft end) ?
I have found one listing for a add on slip clutch for about $100 thats describes itself as what I need but cant get in touch with the guy to verify it before purchasing.
Ive work google out searching for alternates but have found none
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #2
You want to turn your 1 3/8 round shaft on the cutter into a 6 spline 1 3/8?
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #4
I looked at TSC and do not see such a thing. I don't remember ever seeing one like that. If you want it for the over running clutch, that usually goes on the tractor shaft. If you are trying to adapt a double spline pto shaft, it might be easier to just get the right shaft.
Here are some but I havent been able to get pricing. Bare Co USA - Heavy Duty Safety Clutches
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #7
OK. I see what you are trying to do. Most of that style fit shafts that have keyways in them. You can get a pto shaft that has the slip-clutch built in.
   / Shear bolt to 6 spline adapter OR addon slip clutch Shear bolt to 6 spline available? #8
TSC SKU #270109299
Trailer w/ 500 Gal Tank & Pump (A50121)
Trailer w/ 500 Gal...
EZ-GO D499 Electric Golf Cart (A51694)
EZ-GO D499...
2014 INTERNATIONAL 7400 SBA 42 LUBE TRUCK (A51406)
2014 INTERNATIONAL...
2011 Ram 1500 4x4 Crew Cab Pickup Truck (A50323)
2011 Ram 1500 4x4...
John Deere 825I Gator (RUNS) (A50774)
John Deere 825I...
Case IH Farmall 75C (A52349)
Case IH Farmall...
