Rotary Cutter Shear Bolt and Slip Clutch
   / Shear Bolt and Slip Clutch #1
hydro2
Karns City PA
Mahindra 4035
I bought a used brush hog and it appears to have both a shear bolt and a slip clutch. I figured it would have one or the other. Am I correct in that assumption?
Thanks!
   / Shear Bolt and Slip Clutch #2
I would think so also.
Could put a high grade in place of the weaker shear.
Thanks for the response. I will take some pics of it.
As promised a pic. Sure looks to me like a shear bolt and a slip clutch.
   / Shear Bolt and Slip Clutch #5
Could be the machine was built with a shear bolt and someone added a slipclutch. Could be the PTO shaft is attached to the slipclutch with the pictured bolt and also a key, in which case the bolt isn't a shearbolt at all. At any rate, given the slipclutch is present, use the a grade 8 bolt, or if metric, a bolt with 10.9 on the head to affix the shaft to the slipclutch. You don't need for the bolt to shear when a properly serviced and adjusted slipclutch is present.
   / Shear Bolt and Slip Clutch #6
DON'T use a grade 8 bolt. If the slip clutch fails a shear pin still provides protection. If the shear pin fails the slip clutch isn't working properly. Either way why not have double protection ???? MikeD74t
   / Shear Bolt and Slip Clutch #7
Tens of thousands of rotary cutters are protected by slipclutches alone; when properly maintained and adjusted, they work flawlessly. There is no need to be inconvenienced by a broken shearbolt when slipclutch protection is present. If the OP plans to rely on a shearbolt, he may as well remove the clutch.
At any rate, there is no clear evidence that the bolt acts alone in securing the yoke to the shaft.
   / Shear Bolt and Slip Clutch #8
Does that bolt go thru the center of the splined shaft, or just kiss a slot in the side of the splined shaft? The latter is meant for axial retention, not shear protection.
I guess in will pull the bolt and see if the shaft is retained by the bolt. Thanks for all the input so far.
   / Shear Bolt and Slip Clutch #10
If the shaft is splined, it matters not where the bolt passes, it is NOT a shearbolt. The yoke can't rotate freely on the shaft if both are splined. :confused2::confused2:
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55852)
2006 iDrive...
2015 Ford F550 Bucket Truck - Altec AT40M Boom - Powerstroke Diesel - Automatic Transmission - 4X4 (A55302)
2015 Ford F550...
JOHN DEERE ROW MARKERS - SET OF STACK FOLD 12 ROW 30 INCH ROW MARKERS (A55315)
JOHN DEERE ROW...
2002 AMERITRAIL 32FT GOOSENECK TRAILER (A58214)
2002 AMERITRAIL...
2003 Big Tex 10PI...
2014 Aerway Aerator (A55973)
2014 Aerway...
