Rotary Cutter Shear Bolt and Slip Clutch
   / Shear Bolt and Slip Clutch #1
hydro2
Gold Member
Karns City PA
Mahindra 4035
I bought a used brush hog and it appears to have both a shear bolt and a slip clutch. I figured it would have one or the other. Am I correct in that assumption?
Thanks!
   / Shear Bolt and Slip Clutch #2
I would think so also.
Could put a high grade in place of the weaker shear.
Thanks for the response. I will take some pics of it.
As promised a pic. Sure looks to me like a shear bolt and a slip clutch.
   / Shear Bolt and Slip Clutch #5
Could be the machine was built with a shear bolt and someone added a slipclutch. Could be the PTO shaft is attached to the slipclutch with the pictured bolt and also a key, in which case the bolt isn't a shearbolt at all. At any rate, given the slipclutch is present, use the a grade 8 bolt, or if metric, a bolt with 10.9 on the head to affix the shaft to the slipclutch. You don't need for the bolt to shear when a properly serviced and adjusted slipclutch is present.
   / Shear Bolt and Slip Clutch #6
DON'T use a grade 8 bolt. If the slip clutch fails a shear pin still provides protection. If the shear pin fails the slip clutch isn't working properly. Either way why not have double protection ???? MikeD74t
   / Shear Bolt and Slip Clutch #7
Tens of thousands of rotary cutters are protected by slipclutches alone; when properly maintained and adjusted, they work flawlessly. There is no need to be inconvenienced by a broken shearbolt when slipclutch protection is present. If the OP plans to rely on a shearbolt, he may as well remove the clutch.
At any rate, there is no clear evidence that the bolt acts alone in securing the yoke to the shaft.
   / Shear Bolt and Slip Clutch #8
Does that bolt go thru the center of the splined shaft, or just kiss a slot in the side of the splined shaft? The latter is meant for axial retention, not shear protection.
I guess in will pull the bolt and see if the shaft is retained by the bolt. Thanks for all the input so far.
   / Shear Bolt and Slip Clutch #10
If the shaft is splined, it matters not where the bolt passes, it is NOT a shearbolt. The yoke can't rotate freely on the shaft if both are splined. :confused2::confused2:
SHOP BUILT FLARE STACK (A53843)
SHOP BUILT FLARE...
UNUSED FUTURE FM57 57" HYD FLAIL MOWER (A57193)
UNUSED FUTURE FM57...
ATV STORAGE SEAT & ATV CAMO SEAT (A57192)
ATV STORAGE SEAT &...
2003 Ford E-250 Wagon Passenger Van (A56858)
2003 Ford E-250...
Wolverine Single Cylinder Grapple Bucket Mini Skid Steer Attachment (A53421)
Wolverine Single...
NEW HOLLAND T4.75 TRACTOR (A57192)
NEW HOLLAND T4.75...
