Sharpening Bush Hog
/ Sharpening Bush Hog #1
pennwalk
Lancaster PA
Yanmar 186D
I read that it was a good idea to keep the bush hog blades "sharp" to reduce the load on the tractor. When I looked at replacement blades at TSC I was surprised to see that the edge was flat. When I tipped the bush hog up to inspect the blades I found the edge to be round but not much wider than the new blade but the outside corner is rounded off too. I understand from a lawn care friend that the outer end is where the action is. How do I sharpen the blade and when is it time to get a new one?
Chris
/ Sharpening Bush Hog #2
Chris, a "sharp" blade means you have thin metal on the leading edge. When it hits something hard like a small tree or sapling, that edge can be nicked, notched, or bent. So I believe it's customary for brush hog blades to have an edge that is approximately 1/8" thick. It shatters and tears brush without damage to the blade. Now if you're only mowing grass and weeds (soft material), then I see no reason not to have a sharp edge on the blades; similar to a lawn mower.
<font color=blue>How do I sharpen the blade and when is it time to get a new one?</font color=blue>
I have removed blades and sharpened them on a bench grinder, and I've also sharpened blades without removing them by using a 4" angle grinder. I suppose it could be done with a hand file, but not by this old man./w3tcompact/icons/laugh.gif That would just take too much time and effort. As for replacement, if it's bent, cracked, bolt holes wallowed out - in other words just inspect them for damage and replace them if they are. Otherwise, I don't know how much wear you want before replacing them. I replaced mine when the "sharpened" section of the blade got narrower than the rest of the blade. When you sharpen them, try to take the same amount off each blade so they stay balanced.
/ Sharpening Bush Hog #3
Chris
I was just reading an article in Progressive farmer about Bush hog blades. The article suggest's that these blades be professionally sharpened, because balance is so important. The vibration unbalanaced blades can cause can be very damaging to the mower.
Solo
Bird I have admired your posts here on TBN for a while now. I don't know if I am thinking about this too much. After all a bush hog is a pretty crude device which the folks down under aptly name the slasher. But I was wondering. If the outside leading edge does the cutting. On a new blade it is a "sharpened" corner. On my blades the outside corner is somewhat rounded (darned rocks!). Do I just grind away at the round so that the 1/8 inch edge goes around the corner or do I grind away the round so that the whole edge is at a small angle and the square corner is reestablished?
Chris
I was thinking about just giving in and taking them to the shop but I was thinking that I ought to be able to do it. Its not rocket science. The shop that I am using is pretty slow and sure as shooting on the next sunny day it will come to me like a revelation that I ought to be out bush hogging and sure enough the blades will be in the shop so I will have to slink back down to the basement for a virtual tractor fix but the real think is better.
Chris
/ Sharpening Bush Hog #6
The replacement blades are fairly inexpensive... say from $10 - 20. ea. ... but the removable and re-torquing is actually the time consuming thing...
I would use a brand new blade as a template for your guide... I think you'll be very surprised with the "rounded new edge"... and unless you're putting quite a few hours a year on a brush hog alone...{hundreds...?}, you can probably go a few years before it ever gets to the sharpening stage... /w3tcompact/icons/wink.gif
/ Sharpening Bush Hog #7
I have alot of luck sharpening blades w/a small hand grinder..41/2 disc w/stainless steel pad..for you can w/ease get the right angle,and you don't burn nor nick the blade w/a stone disc.
I do sharpen the end of the blade a tad for that might see the first object to be cut,I also lube the heck out of the bolt and housing threads so next time w/ease to remove the blade.
/ Sharpening Bush Hog #8
<font color=blue>Do I just grind away at the round so that the 1/8 inch edge goes around the corner</font color=blue>
Chris, I'm no expert on this, but I don't grind "around" the corner; just sharpen straight across. And I don't worry about a slighly rounded corner at the end. And as I said, I've sharpened some without removing them, and I've also used the bench grinder, but I prefer removing the blades and putting them in the vise on the workbench and then sharpening them with the angle grinder. Then I weigh them to make sure the weight is the same for each blade in an effort to keep them balanced. And I may very well be over doing it a bit and taking too much time, but I thoroughly clean them on a wire wheel on the bench grinder before sharpening; same as I do with the lawnmower blades.
/ Sharpening Bush Hog #9
Hi Bird,
When I was a kid… after sharpening, my friends’ Dad {God bless his soul} would put the blades on a scale… one on each side {old fashion-looked like the “scales of justice”} to adjust for balance…
Today, with the finish mower blades you re-sharpen them, but with the larger rotary cutter blades {brush hog style}, they recommend replacement versus “re-sharpening”… due to the “tempered” and “hard-surface process” technology in use now…
Evidently using the grinder while sharpening the edge also changes the “temper” of the steel {obviously its heating up the metal} and can make the blade “harder” causing it to become brittle in some instances and… break/shatter… on up to 1” stuff it may not occur but approaching 3-4” or more stuff it can become a deadly/dangerous situation…
__________________
Enough of that… how’s the Tool Truck business been the past week…? Is your brother on vacation? Or do you feel like coming out of retirement…? /w3tcompact/icons/blush.gif
/ Sharpening Bush Hog #10
I had an Uncle who used to say "You can cut brush with a school bus if you spin it fast enough". Kinda cute and partially true. As Bird pointed out, if all you are cutting is grass, sharpen 'em up pretty good. If you are truly bush hogging they need not be that sharp and it's better on the blades if they're not.
/ Sharpening Bush Hog #11
John, I don't have a balance scale or I'd probably do that, too./w3tcompact/icons/wink.gif
<font color=blue>they recommend replacement versus “re-sharpening”… due to the “tempered” and “hard-surface process” technology in use</font color=blue>
Makes sense and sounds logical to me. My previously owned Bush Hog manual had instructions for sharpening (and leaving a flat front edge), but in my currently owned Howse manual, I haven't found any mention of sharpening; just replacement; maybe you've stated the reason. Actually I have sharpened the Howse blades (only once in two years) and just tried to go very slow a little at a time to generate as little heat as possible (and I'm certainly not saying that was the best thing to do; only that it's what I did do).
My brother had to retire from the Tool Truck business because of a physical disability, but shortly after he retired, the guy who took over that route asked my brother to run it for a week for him because he had a son in the hospital in serious condition, and my brother did. So this time when he asked my brother to do it again, my brother said he just couldn't handle it alone, so we did it together. My brother knows a lot of the tools much better than I, and he knows the town, the customers, and the company's computer system better, so I was mostly just the driver./w3tcompact/icons/laugh.gif Lots of climbing in and out of that big truck, but I really liked that Freightliner with a 310 or 315hp Cat engine and Allison transmission.
/ Sharpening Bush Hog #12
<font color=blue>I understand from a lawn care friend that the outer end is where the action is. </font color=blue>
I'm pretty sure that on a rotary cutter, the main action is along roughly the first 2-1/2" of the blade. Here's how it figures: Let's say an average mowing speed is 3.5mph - or about 62" per second. Most rotary gearboxes are around 50% step-up over pto rpm - so the blades turn approx 790 rpm or 13.1 rev/sec. The amount covered by each blade is 62"/sec divided by 26.2 blade sweeps per second. So each blade cuts about 2.4" of new material each time around. Of course this is the max and it tapers down at the ends of the arc.
Whether the edge is rounded or not is more about material temper and resistance to chipping - not about how it cuts. Finish mowers and walk-behinds run much faster and cover much less ground per revolution - so it may be a factor there.
Dick Bargeron ---- cheerful refund if info is bogus /w3tcompact/icons/smile.gif
I decided to take John Millers advice. Picked up a set of King Kutter blades for my old KK 48" hog were $13 each from TCS. King Kutter recomends replacing the bolts at the same time. They were $21 for the set. Then to be on the safe side I picked up a 3/4 drive socket set for $59. I wasn't sure that my 1/2 inch set would be up to the job. I looked at buying just the tools I would need for the job at Sears but the Slider bar,extention and socket would have been over $60. Of course the craftsman tools look much nicer but I cheaped out. Time will tell how the chinese tools hold up. Plan to scrounge up a nice long piece of pipe in case the bolt tries to give me any trouble. The King Kutter manual recomends keeping your blades sharp. I'll let you know if I can tell any difference. I may take the old blades to the sharpening shop just to see how they do it. I do know that they use a water cooled grinder so I hope that it won't mess up the temper.
Chris
/ Sharpening Bush Hog #14
Chris,
If you are replacing the bolts anyway, you may want to line up someone with an acetylene torch just to save yourself some trouble in removing the old ones, but the ones you have may come off easier than I think. Zap 'em with penetrating oil a couple of times a day for few days before you try them and they may come off without much of a problem.
Best of luck, Jeff
/ Sharpening Bush Hog #15
<font color=blue>When I was a kid… after sharpening, my friends’ Dad {God bless his soul} would put the blades on a scale… one on each side {old fashion-looked like the “scales of justice”} to adjust for balance…</font color=blue>
Quick trick I use similar to that, is to hang the blade by the center bolt hole (if there is a center bolt hole), on a nail... comes close enough if you don't have a scale in the barn. /w3tcompact/icons/wink.gif
/ Sharpening Bush Hog #16
You got me thinking...on a rotary cutter you'd want both blades to weigh the same. You could build a balance scale. Take a board two feet long, stick a nail in each end, drill a hole exactly in the center of the nails, drive a nail into something to hang it on and use that to balance the blades. Just grind a little more off of the heavy one. You wouldn't have to be exact, the first time you bounce one blade off a rock your balance goes to pot anyway.
/ Sharpening Bush Hog #17
I do the same here on mower blades with a center hole. I have a short rod welded to my grinder stand. As for rotary cutter blades I use a bathroom scale. Since they are so heavy, that bathroom scale works great to match the blades.
/ Sharpening Bush Hog #18
If it was not too much of a hassle changing the blades an individual could have 2 sets of blades...1 for the brush and a sharper set for the grass.
/ Sharpening Bush Hog #19
Muhammad, for my finish mower blades (hole in center), I do something similar except I use a very small round shafted screwdriver instead of a nail. But since the rotary cutter blades are so different (hole in one end) and so heavy, I have scales in the shop that go to 20 pounds (10# scale and twice around) that I can hang one blade at a time on to weigh them.
/ Sharpening Bush Hog #20
bgott,
Seems that if you use a longer board (or whatever) will have a more sensitive device. Also, I wouldn't be to hasty to just drill that thing dead center and start using it as wood can vary considerably in density over even a small distance, at least when you buy cheap stuff like I do. You could literally give it a whorl 3-4 times and see if it favors one end over the other and add some weight to the light end to balance it.
In the olden days when flying gas powered model aircraft (the RC units had tubes- valves for the UK), we used to ballance the props on the high RPM engines (hot rodded). To make a sensitive tester we put a snug fitting shaft through the hole in the center of the prop and let each end of the shaft rest on the up turned edge of a single edged razor blade (carefully leveled). This worked well for even props less than 5-6 inches in total length. Once "micro-ballanced" and then varnished, you could easily detect a small difference in the weight of a coat of varnish or butyrate dope. (A little 600-1200 grit sanding would get it under control.) The Rube Goldbergs among us (I like to include myself in that august group) could easily scale up something from that approach for free out of the junk box or for a couple bucks from the H/W store.
Patrick
2020 DRAGON 150 BBL ALUMINUM VACUUM TRAILER (A60736)
2020 DRAGON 150...
JMR STUMP/ TRENCHING BUCKET (A56857)
JMR STUMP/...
Truck Mounted Carpet Cleaning Extraction Machine (A57454)
Truck Mounted...
2022 FORD E350 BOX TRUCK (A58018)
2022 FORD E350 BOX...
1988 Lufkin CM-320D-305-100 Road Runner Mobile T/A Oil Field Pumpjack (A60352)
1988 Lufkin...
2019 CATERPILLAR 305.5E2 CR EXCAVATOR (A62129)
2019 CATERPILLAR...
