   / Share Pics of People Hauling or Towing Something Wrong #20,771
I don't think it matters for how long somebody has been towing, but what does count is what they're towing.
I doubt that there are many trailers with a 7,000 lb. GVWR or more that doesn't come with at least a 2-5/16" coupler. Or a 3", or a lunette eye. And then there are 5th wheels.
I tow upwards to 14,000 lb. GVWR. You can not be in a stupid mode ever with loads this high. 2-5/16 ball, and upgraded chains. I once had a locked coupler jump off the ball thru a bad uneven intersection. The chains saved everything. I bet if the OE chains were on the trailer, it would have rolled on it's side.
   / Share Pics of People Hauling or Towing Something Wrong #20,772
Lunette eye??
You mean a pintle hook?
   / Share Pics of People Hauling or Towing Something Wrong #20,773
Lunette eye??
No, I meant a lunette, or tow ring as they're also called.
After all, we are discussing couplers for trailers, right? The pintle hook normally goes on the vehicle that pulls the trailer with the lunette.
Admittedly, not that I remember why, but one time I did indeed put the pintle hook on the trailer, and to be nice to it, installed upside down.
This isn't quite as crazy at it may sound. Most of my bumper pull trailers have a receiver on the tongue, so I can put various things on them, including upside down pintle hooks.
   / Share Pics of People Hauling or Towing Something Wrong #20,774
Lunette eye??
Apparently the hitch on the vehicle is called a pintle and the trailer side ring is a lunette. I thought it was collectively called 'pintle'. But yes, they are both referencing one single towing connection type.
   / Share Pics of People Hauling or Towing Something Wrong #20,775
I should probably explain my fetish for having receiver tubing on most everything.
I've put them on regular blades, box blades, trailers (front and rear), you name it.
This allows my to put just about anything anywhere, and only need a few pintle hooks and tow rings. For example, that rectangular tubing sleeve at top left makes it possible to use 2x2 1/4" wall tubing to extend the tongue of a trailer, or the reach of my "sky hooks" (that's a different story, those go on the loaders).
I have also made a few other gizmos. For example, this one can be used to raise the effective tongue height of a trailer, or lower the height of a receiver. It's kinda like a big Lego, but for towing stuff.
For regular road use, it's almost all gooseneck trailers, and a few with a tow rings. And while I have a few of the multi-ball ballmounts, I never use them. If for no other reason, because most have a ridiculous 7/8" ball on them.
   / Share Pics of People Hauling or Towing Something Wrong #20,778
I've been towing for 60 years & never needed anything larger then 2"
1 7/8 worked for many a year.
It depends on the weight your pulling.
2" balls are usually rated to 7,000lbs.
2 5/16 goes up to 15,000lbs.
Any trailer rated for over 7,000lbs will come with a 2 5/16 hitch, or pintle hook.
   / Share Pics of People Hauling or Towing Something Wrong #20,779
   / Share Pics of People Hauling or Towing Something Wrong #20,780
There's definitely good reason for having 2-5/16". I think the original argument made a good point though, in that 2" and 1-7/8" are so similar that having both of these standards yields more trouble than solutions.
How many of us have backed up to a trailer where the tongue is coated in paint so thick you can't even find the stamped coupler size? Towing a lot of boats at the marina, this was a constant source of frustration. I had to always make sure I had both size balls in the truck, and the ball size I needed was always on the wrong height (drop) hitch.
Having both 1-7/8" and 2" standards should have never been allowed, and discontinuing one or the other cannot come soon enough, IMO. I honestly wonder how many trailers hop off balls every year, due to people putting 2" couplers onto their 1-7/8" balls, not even realizing it's not a match. When you skip up to 2-5/16", the mismatch is obvious to even the most amateur hauler, but I could see a lot of less experienced people mixing up the smaller two sizes without even realizing it.
2022 LOAD TRAIL GOOSENECK TRAILER (A52472)
2022 LOAD TRAIL...
2013 Ford F-150 4x4 Crew Cab Pickup Truck (A51692)
2013 Ford F-150...
(1) 14ft Tarter Gate (A51573)
(1) 14ft Tarter...
2014 Chevrolet Spark Hatchback (A50324)
2014 Chevrolet...
