   / Share Pics of People Hauling or Towing Something Wrong #19,051
It may not be from the bearing welding to the nut, could be the lopsided wheel hub rubs the nut hard enough to rotate the nut to shear the split pin. But I have seen the outer wheel bearing stuck to the retaining nut to the point that it requires a hammer and punch to separate the two.
Red hot nuts and inner races dont weld together untill you stop so they can cool down and fuse. Then it takes a lot of determination to shear a castle nut cotter pin, with that much resistance when you take off.
I have split wheel hubs and even transmission casings when bearings jammed, but never sheared a cotter pin. To be honest, with the tire radius, wheel load, 0.5 tire to road friction, 30mm castle nut inner diameter, cotter pin diameter i am used to, i doubt a jammed tire can generate enough torque to shear the cotter pin. The math of an average hub just makes it very implausible, to be honest.
Either way, when youre able to separate the nut and the inner race with a punch and a hammer, thats not enough force to shear a cotter pin.
   / Share Pics of People Hauling or Towing Something Wrong #19,052
Whatever. Something is causing the pin to shear off and the retaining nut to unscrew on the left side of trailer axles.
   / Share Pics of People Hauling or Towing Something Wrong #19,053
It’s magic!
   / Share Pics of People Hauling or Towing Something Wrong #19,054
You don't have to lose the axle nut to have the hub come off. If the outer bearing disintegrates (lack of grease... burns up and comes apart) then the hub no longer has retention.
   / Share Pics of People Hauling or Towing Something Wrong #19,055
Yep...this happened to me. Bearings, wheel, tire...gone! The nut was still there,
   / Share Pics of People Hauling or Towing Something Wrong #19,058
No time for a photo, but today at the merge point of two freeways I saw a CHP officer, flashing lights on, parked behind and protecting a small junk trailer. As we got closer it was obvious the hub and wheel had come off the trailer leaving just the stub axle. Somebody forgot the cotter pin?
Seemed to me the only way to get the pickup and trailer to a safe place would be to just order the pickup to drag the trailer as-is to the shoulder beyond the merge, because getting a wrecker in there and hooked up with a dolly would disrupt traffic and likely cause crashes.
Personally, I would have dragged the trailer to a safe spot before I stopped.
I've done it many times before.
Years ago I had a customer damaged an axle and abandoned the piece of towable equipment on I-40 in Orlando smack dab in the middle of a construction zone.
I just whipped up in front of it while the cop was blocking traffic in that lane. I told the cop to follow me. I latched onto the equipment real quick and dragged it down to a safe spot to complete the repairs.
   / Share Pics of People Hauling or Towing Something Wrong #19,059
HAND SAWS (A58374)
HAND SAWS (A58374)
INBOARD DRIVE (A58374)
2016 FREIGHTLINER  CASCADIA (INOPERABLE) (A58214)
2016 FREIGHTLINER...
FORD DEXTER TRACTOR (A52708)
FORD DEXTER...
2018 Freightliner M2 106 AWD Terex Hi-Ranger TC55 55ft. Insulated Material Handling Bucket Truck (A55973)
2018 Freightliner...
New/Unused 2 Post Car Lift (A57454)
New/Unused 2 Post...
