   / Share Pics of People Hauling or Towing Something Wrong #18,521
Friend of mine slid through a stop sign with his pickup. He was ranting about ABS saying the heavy jets he flew for a living had it and it worked perfectly on them !
It DOES work perfectly on a cleared runway...
Actually it works perfect in every situation except braking in fresh snow on summer tires. Since i keep a set of winter tires with soft rubber and different thread for the odd week it snows here, ABS hasnt bothered me anymore when driving on fresh snow.
Last year i havent used them at all, and the year before i had them under for two weeks. Perhaps its time to use them up this winter before they dry rot...
   / Share Pics of People Hauling or Towing Something Wrong #18,522
Is a mistake to make a general statement about the ability of ABS. Some manufacturers make excellent ABS which works in all conditions. Some make an ABS which only works on dry straight surfaces.
I remember about 25 years ago GM started putting rear wheel only ABS on pickup trucks to deal with the situation of braking with no load in the bed. "But it has ABS!"
   / Share Pics of People Hauling or Towing Something Wrong #18,523
Thats why the Merc Sprinter (and any other vehicle in the same weight class i have been around when i worked in body construction) has a load adjuster, which adjusts rear axle brake force to the load (spring deflection)
   / Share Pics of People Hauling or Towing Something Wrong #18,524
What happened to the original thread ?
   / Share Pics of People Hauling or Towing Something Wrong #18,525
1986 VW Golf too, but only the premium version, not the base model I had. Was a variable proportioning valve attached to the rear suspension.
After a couple near misses with brakes on the VW I added ABS to the essential list for next vehicle. Bought 1993.5 Infiniti G20 5-speed. Perhaps the best car I have ever owned. The 4-wheel ABS was perfect by every means I could tell.
The G20 had two faults: the wonderful 2.0L engine had electronic ignition but still had a distributor. Distributor cap was expensive. The factory wheel alignment specs for rear wheels were great for track performance specs to compare with BMW 3-series but awful for tire wear. Fortunately no matter camber was not supposed to be adjustable on the rear it adjusted the same way as the VW front. Rear strut clamped to hub casting with 2 bolts same as VW. Enough slop in those bolt holes to adjust.
   / Share Pics of People Hauling or Towing Something Wrong #18,526
My Dakotas had that. Talk about a scary ride on snow!!!! I finally learned to run in 4WD if there was even a slight snow cover on the ground. Simliar to the rears on a 4WD tractor, the front brakes would slow or stop both axles.
It will come back, just as it always does. People just need to take some pictures of towing wrong.
   / Share Pics of People Hauling or Towing Something Wrong #18,527
ok so you wants some pictures, I do believe this trailer was hauled wrong before I loaded it on my trailer and yes that was a 4 leaf spring before.
   / Share Pics of People Hauling or Towing Something Wrong #18,528
   / Share Pics of People Hauling or Towing Something Wrong #18,530
Ouch!!! They either had it overloaded or the springs were tired. It looks like something you can easily fix up and use, however.
Nah, it's not the springs fault, the nut is still on the spindle but the hub is missing, they've neglected to add grease to the wheel bearings for many many miles, the tire exited the situation then they continued to drive for long enough to wear through the backing plate, U bolts and the springs left the situation too...
2019 GALYEAN EQUIPMENT CO. 150BBL STEEL (A58214)
2019 GALYEAN...
2012 Big Tex 14ET-20BK 20ft T/A Flatbed Trailer (A55851)
2012 Big Tex...
2017 Dodge Ram SLT (A55314)
2017 Dodge Ram SLT...
2025 GIYI MULCHER SKID STEER ATTACHMENT (A58216)
2025 GIYI MULCHER...
New/Unused Quick Attach Pallet Forks (A57453)
New/Unused Quick...
Link-Belt 75X3 (A53317)
Link-Belt 75X3...
