/ Share Pics of People Hauling or Towing Something Wrong #17,783
hanging around for a job.
/ Share Pics of People Hauling or Towing Something Wrong #17,784
No bridge? Get on the boats.
Bruce
I was hoping to see the guy that was holding the boat on the right side get nutted by the rear ramp flinging up.
/ Share Pics of People Hauling or Towing Something Wrong #17,785
I think they have done that before.
/ Share Pics of People Hauling or Towing Something Wrong #17,787
License plate would indicate Poland
/ Share Pics of People Hauling or Towing Something Wrong #17,788
I drove a Ford 9000 flatbed with a 24' flat bed wagon behind it. With practice I could back it over uneven ground in a straight line or around a slight corner. I have heard of people (never seen it) who could back a set of doubles. One won a bet from a former boss when he said he could back his set around the small restaurant at truck stop. He was allowed one or two pull-ups but had to back it from where it was parked back to where it was parked. My boss said he had bet $200 and lost but it was worth it to see the man's skill.
I can back a set of doubles into a dock if I can get somewhat straight in front of the dock. I also often don't pull the dolly and 4 wheel it in with the dolly hooked to the tractor. It just takes practice and very small corrections. The trick is not to let the dolly get much of an angle. You can't make much of a turn when backing doubles. 90 degree turns are fine four wheeling the rear trailer. Basically when backing doubles if there is more than 8 inches of the rear trailer sticking out behind the front one you are at the limit. You can't stop the dolly from turning. Also the tractor can't be turned much on the first trailer or you can't swing it quickly enough to correct. Basically you are thinking about the next correction while your making the current one. It's easier to learn it with a long front trailer and a short rear trailer. Like a 40 - 24 set. But once you learn how even 2 28s will do it. Triples forget it. You will loose control of the back dolly almost immediately.
/ Share Pics of People Hauling or Towing Something Wrong #17,789
I pulled a set of basically hay doubles. A 26' 1 axle lead and a 24' 2 axle pup on a turntable with an ~8' reach, not a converter and no turntable lock. The tractor was a W800 short wheelbase tandem axle. I went to a place in north Seattle on Aurora Ave North called Seattle Glass Block to pick up several pallets of glass block and grout. The shipper said "back it down in here." It was a 90 degree back down with some side angles thrown in just to make it fun. Aurora is the main north/south arterial and 5 lanes wide. I informed him it was a set of doubles to which he replied, the guy who used to drive that truck could do it. I heard the same story in a couple of other places. Around corners, up hills, the guy apparently could do it. I don't know if it was the same guy at the truck stop restaurant, but it was in the same area. The truck stop was in Mount Vernon WA, about 60 miles from Seattle and 30 miles from Bellingham where my employer with the Kenworth was located.
They brought the pallets up to me and loaded them from one side and pushed the pallets over, because Aurora was too busy to take a forklift on.
I practiced, and I could back it about 1-1/2 truck lengths on an uneven uphill grade before it became FUBARed.
/ Share Pics of People Hauling or Towing Something Wrong #17,790
Fortunately it's small and light enough to use the (manual method) if I get in a bind and not grossly overloaded lol slowly but surely I'm getting a little better at it using old beat up garden tractors anyway. And can do it pretty competently if I push it with an ATV.
I have a heckuva time backing up anything with an ATV. That is why I put a front hitch on the FEL of my tractor and use that to move trailers around.
/ Share Pics of People Hauling or Towing Something Wrong #17,791
2 axle smaller hay type wagons aside, That's why I made a detachable front hitch for my ATV so I could move and position smaller road trailers.
/ Share Pics of People Hauling or Towing Something Wrong #17,792
I have seen guys back doubles around a corner. I can't do it. I have delivered the Seattle Glass Block before. Basically Aurora Ave sucks. Actually most of Noth Seattle sucks. Except Freemont. The free freak show driving through there makes it worth it.
/ Share Pics of People Hauling or Towing Something Wrong #17,793
Since you've been there, then you know it's quite a feat to back a set like that down in there. Happily, I left that job 20 years ago and moved on. Now I am working on my 6th year of retirement. I couldn't remember where they were exactly, but my memory (such as it is) has me thinking it was between 125th and 145th
/ Share Pics of People Hauling or Towing Something Wrong #17,794
I didn't back a set in there. I wouldn't do that off a main road like Aroura. That would not make sense. It's been many years for me as well. I have run the Chehalis area for the last 17 years. I went north to Everett before that. So North Seattle was on my way back then. We don't pull doubles on routes anymore. 48 foot lift gates are more efficient. But I pull them once in a while to Portland. And sometimes triples to Hermiston from Portland.
/ Share Pics of People Hauling or Towing Something Wrong #17,795
Or ppp on the owner of car.
/ Share Pics of People Hauling or Towing Something Wrong #17,796
I still remember when the tdi Jettas were all the rage (before vws) emission scandal, can't remember all the city folks I assisted when there diesel wouldn't start cause of cold weather and being unable to plug there car block heater in at there urban apt complex.
/ Share Pics of People Hauling or Towing Something Wrong #17,797
I wonder if that's legal to ride in it when underway? Lol
/ Share Pics of People Hauling or Towing Something Wrong #17,800
My objective is to promote humor. :) I suspect, based on your profile name, you may not understand that concept? Since I’ve offended you, I apologize and will delete the offensive post.(y) If there are any others, please let me know and I will address those as well.
You need not delete it because some folks are a bit sensitive; plenty of us found it amusing, as it's just a meme.
2020 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A59904)
2020 FREIGHTLINER...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60430)
KNOW BEFORE YOU...
19008 (A56859)
19008 (A56859)
2021 BOBCAT 566 R-SERIES SKID STEER (A60429)
2021 BOBCAT 566...
(APPROX.15) 5/8"-4'X8' OSB (A60432)
(APPROX.15)...
2023 BOBCAT E50 R2-SERIES EXCAVATOR (A60429)
2023 BOBCAT E50...
