   / Share Pics of People Hauling or Towing Something Wrong #17,491
When a customer's horses are starving. Draw-Tite all the way.
   / Share Pics of People Hauling or Towing Something Wrong #17,492
Of course you "expect it to" but if it is broken it won't. If your truck is broken then does that prove all ICE trucks are defective and unsuitable in the cold?
My 2013 Tesla Model S 85 about the same day as the viral media report. Might notice the red "battery heat" icon indicating the battery heater was in use during charging. "Inside" is the car's passenger compartment. It would seem heating the battery (which occupies the entire floorboard) warms the inside of the car.
This is a snippet from the TeslaFi.com logger.
My main point was that nineteen degrees isn't cold. My other point about needing whatever I drive to be dependable was equally true though. I rarely let my fuel tank get below half; but when leaving the tar, I fill up at the last station I go past.
I don't need all of the bells and whistles to tell me what the temperature is, inside or outside the car. I'm firmly implanted in the KISS camp.
   / Share Pics of People Hauling or Towing Something Wrong #17,493
Is there a category on the Corvette forums for towing? Do they debate payload, air shocks and airbags?
   / Share Pics of People Hauling or Towing Something Wrong #17,495
How about properly positioning the load.
I often see tractors being pulled backwards on a dual-axle utility trailer, sometimes with attachments, some without. I’ve often wondered which is truly the best way.
I have a [AFFILIATE=1, nofollow=true, newwindow=true, title="Kubota"]Kubota[/AFFILIATE] with an FEL and a box blade (sometimes a rotary cutter which sticks off the back end of the 18’ trailer about one foot.
I’m not sure if I should be towing forwards and backwards and I don’t know how the weight is truly distributed when I do this.
Thoughts?
   / Share Pics of People Hauling or Towing Something Wrong #17,496
I don't think there is a right or wrong on loading direction. It all depends on the attachments and weight distribution. I find it convenient to load forward, but with my loader and box blade on I have to be as far forward as possible for tongue weight. John Deere recommends loading backward but that's in case the hood opens. I don't worry about that.
   / Share Pics of People Hauling or Towing Something Wrong #17,497
   / Share Pics of People Hauling or Towing Something Wrong #17,498
I know with some JD’s they worry about the hood opening and getting ripped off so they load backwards.
   / Share Pics of People Hauling or Towing Something Wrong #17,500
I have a [AFFILIATE='1, nofollow=true, newwindow=true, title="Kubota"']Kubota[/AFFILIATE] with an FEL and a box blade (sometimes a rotary cutter which sticks off the back end of the 18’ trailer about one foot.
Thoughts?
This is what I use. You should know the approximate weight of the trailer and load. I move it around until the tongue weight is between 10 and 15 percent. Then tie it down. No guesswork. I have 2 of them. I have 2 trucks and if we are using both to take 2 trailers somewhere we are both safe. Also I have 1 trailer with a 2" ball so one has normally got that ball in it. But I have 2 2 5/16 balls so I can switch that one. It works well. Sometimes I get a chance to get wood from jobsites so we take the flatbed behind the HD truck and the dump trailer behind the 1500. I can haul enough logs to make more than 4 cords of wood that way. Some species of wood have a cost to get them hauled off so the superintendent is willing to meet me or have an employee meet me on a Saturday to load it up. But they are not going to wait for me to make several trips. It doesn't take long to load it, so the more i can haul the more i get. The dump trailer has the 2" hitch. But we also go to Corvette shows and meet ups. I pull the RV behind the HD and she pulls the Vette on the tilt deck behind the 1500. They both need 2 5/16 balls. It only takes a minute to switch the ball in the ball mount. They also offer the same key for all locks. I have gone to their hitch locks coupler locks and pad locks. All take the same key. Really handy. And future lock purchases you just put your key number in the field and they match too.
CHALLENGER MT575D (A58216)
CHALLENGER MT575D...
CAT 930M (A58216)
CAT 930M (A58216)
2832 (A58376)
2832 (A58376)
2015 Ford Explorer AWD SUV (A56859)
2015 Ford Explorer...
SEMI AUTOMATIC QUICK CHANGE FOR MINI EXCAVATOR (A58214)
SEMI AUTOMATIC...
2009 MULTIQUIP 25KW GENERATOR (A58214)
2009 MULTIQUIP...
