   / Share Pics of People Hauling or Towing Something Wrong #13,481
Perfect for putting double the tongue weight on your truck, won't damage the tarmac. Wonder how it works at 60 miles an hour though!
For about a minute.
   / Share Pics of People Hauling or Towing Something Wrong #13,482
Well if you use red, green ,or moly grease you might get 2 minutes....
   / Share Pics of People Hauling or Towing Something Wrong #13,483
Springs are grossly overrated. Once the axle comes up against the frame, he's golden.
   / Share Pics of People Hauling or Towing Something Wrong #13,485
It should hold up alright. If my math is correct it will only be turning at 10,089 RPM. That is estimating the roller diameter at 2".
Edit.
If the roller were 3" diameter the RPM is reduced to 6,726.
   / Share Pics of People Hauling or Towing Something Wrong #13,486
Should be no problem, it's about the size of a model airplane engine which turns at something like 20,000 to 30,000 rpm. So, 10,089 rpm is well below that.
   / Share Pics of People Hauling or Towing Something Wrong #13,487
Only one strap on the load. The DOT will get him for that.
   / Share Pics of People Hauling or Towing Something Wrong #13,489
it's nitro car engines that run 30k rpm, most plane engines run in the 12k rpm range... Not arguing, just sayin :) prop tip speed gets sonic not much past that in some cases if I remember right, it's been a few years since I've been big into RC flying...
   / Share Pics of People Hauling or Towing Something Wrong #13,490
Found picture:
Bruce
2014 Ram 1500 Pickup Truck (A56858)
2014 Ram 1500...
Ford 8340 (A53317)
Ford 8340 (A53317)
IRTPL LIFT (A58214)
IRTPL LIFT (A58214)
2020 MACK GR64FT (A58214)
2020 MACK GR64FT...
V.E. ENTERPRISES 500 BBL FRAC TANK (A58214)
V.E. ENTERPRISES...
2021 New Holland C327 Compact Track Loader (A57024)
2021 New Holland...
