   / Share Pics of People Hauling or Towing Something Wrong #13,481
Perfect for putting double the tongue weight on your truck, won't damage the tarmac. Wonder how it works at 60 miles an hour though!
For about a minute.
   / Share Pics of People Hauling or Towing Something Wrong #13,482
Well if you use red, green ,or moly grease you might get 2 minutes....
   / Share Pics of People Hauling or Towing Something Wrong #13,483
Springs are grossly overrated. Once the axle comes up against the frame, he's golden.
   / Share Pics of People Hauling or Towing Something Wrong #13,485
It should hold up alright. If my math is correct it will only be turning at 10,089 RPM. That is estimating the roller diameter at 2".
Edit.
If the roller were 3" diameter the RPM is reduced to 6,726.
   / Share Pics of People Hauling or Towing Something Wrong #13,486
Should be no problem, it's about the size of a model airplane engine which turns at something like 20,000 to 30,000 rpm. So, 10,089 rpm is well below that.
   / Share Pics of People Hauling or Towing Something Wrong #13,487
Only one strap on the load. The DOT will get him for that.
   / Share Pics of People Hauling or Towing Something Wrong #13,489
it's nitro car engines that run 30k rpm, most plane engines run in the 12k rpm range... Not arguing, just sayin :) prop tip speed gets sonic not much past that in some cases if I remember right, it's been a few years since I've been big into RC flying...
   / Share Pics of People Hauling or Towing Something Wrong #13,490
Found picture:
Bruce
Welcome to the Farm Metal Sign (A57454)
Welcome to the...
Poly Fuel Tank with Electric Pump (A55851)
Poly Fuel Tank...
Husqvarna Riding mower (A56857)
Husqvarna Riding...
2008 Club Car Electric Carryall 2 Utility Cart (A56859)
2008 Club Car...
2023 Caterpillar 259D3 Two Speed Compact Track Loader Skid Steer (A56857)
2023 Caterpillar...
2019 DRAGON ESP 150BBL ALUMINUM (A58214)
2019 DRAGON ESP...
