   / Share Pics of People Hauling or Towing Something Wrong #13,201
   / Share Pics of People Hauling or Towing Something Wrong #13,202
It’s being pulled by a 5th wheel semi but it’s definitely a pintle hitch trailer. It looks like the truck and trailer was fine for the load so I’m guessing this was caused by bad driving.
Yes to fast around the turn.......
   / Share Pics of People Hauling or Towing Something Wrong #13,204
Just got back from town. On the way out, I saw a UPS truck suddenly pull off at an unusual spot, the shoulder of the down bond side of a bridge, no driveways nearby. Figured mechanical issue maybe. Wasn't sure in my mirror, but oit looked like the rear door was rolled partially up. A quarter mile further on, the other side of the bridge hump, I see a guy scrambling to push a bunch of boxes out of the roadway. Two and two says the UPS guy will be looking for work.
   / Share Pics of People Hauling or Towing Something Wrong #13,205
They are union, he has to screw up a lot bigger than that to get canned
   / Share Pics of People Hauling or Towing Something Wrong #13,206
It痴 being pulled by a 5th wheel semi but it痴 definitely a pintle hitch trailer. It looks like the truck and trailer was fine for the load so I知 guessing this was caused by bad driving.
If it is a pintle trailer, the downforce on the rear axle(s) of the prime mover would be a fraction of the downforce through a fifth wheel; handling of the tractor would be affected. When in the service we had to tow a 5T wrecker (approx. 37,000 lbs.) with the pintle of a fifth-wheel 5T tractor (approx. 20,000 lbs). Tongue weight was about half that of a 100 lb? towbar. Driver said it was the worst "tail wags dog" load he had ever towed.
   / Share Pics of People Hauling or Towing Something Wrong #13,207
Is this diesel a bumper mount, or 5th wheel mount for the trailer,,?
(would it be called a third wheel ? :confused: )
I think the turbo still needs some work,,,
I guess it takes all kinds,,, :laughing:
On another note,, I saw a 40 foot aluminum box trailer (like an 18 wheeler, type trailer ) today,
It had 6 of the 8 tires removed, only one tire was left on each side of the forward axle.
The rear axle was just hanging, no tires.
The trailer was attached to a flatbed, dually F350 Ford pickup,, I have no idea how it was connected,
probably the trailer was just chained to the truck, the trailer was sitting flat down on the flatbed, no gap.
Well, for some reason, the local police had pulled the guy over,,, maybe one of the turn signal bulbs was burned out ??:eek:
I said to my wife,, "Look, the police pulled that guy with the trailer over!"
She said, "I know why he was pulled over, The trailer has the little one square foot vent door on the back open, the guy driving that truck is probably a coyote!"
A "coyote" is a guy that transports illegals, she thought the vent door being open was to supply breathing air for the illegals,,,
So, if you do not want to be pulled over, keep the vent doors on your box trailer closed!!
:D
   / Share Pics of People Hauling or Towing Something Wrong #13,208
:D
Vent doors are intended to be used when driving if needed. But you described many other reasons for the stop.
   / Share Pics of People Hauling or Towing Something Wrong #13,209
I saw this on FB. It at least deserves a worthy mention here. IMG_9161.JPGIMG_9162.JPG
2014 MAGNUM PRODUCTS LIGHT TOWER COMBO (A58216)
2014 MAGNUM...
FUEL PUMP W/NOZZLE (A58216)
FUEL PUMP W/NOZZLE...
John Deere 7 Iron 72in Zero-Turn Commercial Mower (A56857)
John Deere 7 Iron...
CASE ROOT PLOW (A58214)
CASE ROOT PLOW...
2017 Elgin Broom Badger Sweeper, Kubota Turbo Diesel Engine, High Dump, Dual Tilted Gutter Brooms... (A59076)
2017 Elgin Broom...
2018 Bomag BW120 SL Tandem Vibratory Smooth Drum Roller (A56857)
2018 Bomag BW120...
