   / Share Pics of People Hauling or Towing Something Wrong #12,631
I was a distance away so getting a good shot was tough. It's hard to see, but the ball mount is bent. And the safety chains are neatly hung on the trailer:duh: I also don't see a cord for the trailer :confused:
The wheels are 8 lug so likely 7k axles, but the trailer doesn't appear to be built heavy enough for 14k?:confused3: Either way, those pallets are probably 2000-2500lbs (or more?) each and there's 7 of them. Plus the weight of the trailer.
What could go wrong? :thumbsup:
   / Share Pics of People Hauling or Towing Something Wrong #12,632
my thought is the tranny in that old suburban, or the brakes......
   / Share Pics of People Hauling or Towing Something Wrong #12,633
I don't know how you can tell the weight of the pallets, unless just guessing from the perceived trailer sag.
At any rate, I happen to be scrolling through the U-Haul website to figure out if I can haul my SCUT on one of their utility trailers. The 5x8 should carry it, but they list an empty weight of around 900 pounds. The SCUT lists at 1433, plus whatever the loaded tires add. I know it'll be over 2500 total and I'm just not sure I should try it with my 25 year old Taurus wagon with 125K on the clock.
   / Share Pics of People Hauling or Towing Something Wrong #12,634
:rolleyes:
   / Share Pics of People Hauling or Towing Something Wrong #12,635
That Taurus probably has more horsepower than a mid 1970's Toyota pickup,,,
I moved a John Deere 2020 on a John Deere planter trailer back in the early 1980's,, pulling it with the Toyota,,
get-attachment.asp
The trailer was connected to the bumper ball,,, it worked because the trailer axle could be moved to suit the balance desired..
This is how you unloaded it,,, engage a stop in the wheels, loosen a chain that wrapped around the frame to hold the axle,, drive forward,,
get-attachment.asp
If the Toyota could move the JD 2020 with loader (probably 9K pounds) on a 40 foot long trailer,, your Taurus can do it,,,
   / Share Pics of People Hauling or Towing Something Wrong #12,636
hp is one thing, brakes are another.
that is a good thing, give an idiot just enough information to kill himself or some innocent bystander!
   / Share Pics of People Hauling or Towing Something Wrong #12,637
The wheels are 8 lug so likely 7k axles, but the trailer doesn't appear to be built heavy enough for 14k?:confused3: Either way, those pallets are probably 2000-2500lbs (or more?) each and there's 6 of them. Plus the weight of the trailer.
I pickup pallets of that stuff where they make it. The full pallets are 3000 to 3500 pounds. It sucks moving them to the front of the trailer with a pallet Jack. I dump the tractor air ride to make it slightly down hill. If you get too many of them at once you need to single the first 3 of they will overload the tractor drive axles. They are heavy. And that are 3 X 4 foot pallets so they look like they are side by side on there. They would fit like that. So 6000 to 7000 pounds for 4 feet of deck.
   / Share Pics of People Hauling or Towing Something Wrong #12,638
When it was new, it might have been worth a try. Knowing that the transmission is weak and that there are hills along the route, I don't feel it's worth the risks.
   / Share Pics of People Hauling or Towing Something Wrong #12,639
In India or such places they would just pack people on to the hood to level things up a bit. A few hanging onto the ramps would help too.
   / Share Pics of People Hauling or Towing Something Wrong #12,640
Oh and don't forget all the fancy and flashy curtains, carpets and random accessories all over the tow vehicle. :laughing:
2009 FREIGHTLINER M2106 26FT BOX TRUCK (A58017)
2009 FREIGHTLINER...
Brock 36'x17' Flat Bottom Grain Storage Tank (A57148)
Brock 36'x17' Flat...
(1) HD 27ft x 24ft Full Garage Kit Metal Building Frame (A57453)
(1) HD 27ft x 24ft...
2024 Frontier FL1061S Hydraulic Flail Mower (A56436)
2024 Frontier...
2006 WARREN 30' DUMP TRAILER (A54756)
2006 WARREN 30'...
John Deere 1025R Sub-Compact Tractor Mower (A56857)
John Deere 1025R...
