   / Share Pics of People Hauling or Towing Something Wrong #2,521
You should have 2 straps per bale, in case one fails. Or maybe 3 per bale in case two fail. Then put a steel cable net over the whole load. And a tight tarp to stop straw from blowing off into someone's eye.
You can never be too safe. Think of the children.
Bruce
   / Share Pics of People Hauling or Towing Something Wrong #2,522
Quick tip: the top studs on the rear shocks are hard to get to with a wrench to get any real torque on them to bust them loose, especially while trying to keep the barrel from rotating (might not be an issue with a Cali truck), but there is an opening on either side frame rail where you can get a sawzall blade in along the crossmember. Even fumbling around, shouldn't take you more than half an hour to do both. Fronts were pretty easy too. Rockauto had decent prices when I did mine...
TBN members are the best!
Thanks
   / Share Pics of People Hauling or Towing Something Wrong #2,523
Crappy photo's taken off my dash cam in my semi on CA 60 freeway this past week .:confused3:
Picture 1 and 3 are of a pickup loaded way high with pallets . picture 2 is of a suv pulling a trailer loaded the same .
The pickup could get up to maybe 30 mph before he would start losing control , Suv could go a little faster before trailer started really pitching back and forth , taking the suv with .:shocked:
Fred H.
   / Share Pics of People Hauling or Towing Something Wrong #2,524
Bruce
And make sure you have a lead pilot car and a following car with blinking lights, "wide load" signs, etc. Also, make sure you wear a safety vest, hard hat, steel toe boots and eye protection when loading. :D
Or you can go commando like I do and put a block behind the back two. But then I max out a 10 mph and go a few hundred feet on a seldom traveled road. 10,000 bales later, never lost one.
   / Share Pics of People Hauling or Towing Something Wrong #2,527
<img src="http://www.tractorbynet.com/forums/files/trailers-transportation/445878-share-pics-people-hauling-towing-fb_img_1446347434195-jpg"/>
Hope they are just hauling a wood splitter.
   / Share Pics of People Hauling or Towing Something Wrong #2,530
Shouldn't be hard to track down the Connecticut owner of this pickup...
ELECTRIC GOLF CART (A58214)
ELECTRIC GOLF CART...
2022 CATERPILLAR 299D3 SKID STEER (A52709)
2022 CATERPILLAR...
2007 INTERNATIONAL DURASTAR 4300 BOX TRUCK (A58214)
2007 INTERNATIONAL...
CAT D6T LGP DOZER (A58214)
CAT D6T LGP DOZER...
2013 Ford Fusion SE Sedan (A56859)
2013 Ford Fusion...
JOHNSON JW12 OUTBOARD MOTOR (A58374)
JOHNSON JW12...
