   / Share Pics of People Hauling or Towing Something Wrong #11,442
How’s this hauling job? I’d have preferred another strap but I’d depleted the stash behind the seat to only 1. I only had about 2 miles to go and went slow and careful. IMG_7859.JPG
   / Share Pics of People Hauling or Towing Something Wrong #11,443
News link hints 'ladder' and minor injuries.
I saw that also, hence my ambiguous post previously. The picture is obviously a ramp though, as mentioned by the poster who shared the link. At that point that it was in her windshield the driver couldn't have cared less what the proper name was, and you can't expect a reporter to be accurate.
I too. I think it's one of those things where the last thing you see before an event like that, is the one you put the blame too.
Good point. Trucks and their drivers are always fair game when anything goes wrong, anyways.
   / Share Pics of People Hauling or Towing Something Wrong #11,444
I think I'd have split the shingles into two piles.
   / Share Pics of People Hauling or Towing Something Wrong #11,445
I seem to be getting confused easily today. :confused: As per the article; how was the truck driver at fault when all that he did was try to avoid the ladder(-ramp-) as it laid in the road? I do agree that he should have stopped to render assistance assuming that he knew what had happened.
Exactly, if it came off of the road, the truck isn't at fault (unless it was a rock and they didn't have mudflap).
Aaron Z
   / Share Pics of People Hauling or Towing Something Wrong #11,446
Hose gets beat in use. It gets dragged thru all sorts of stuff and dirt embeds in it wearing it in that manner as well. Sun and ozone will kill nylon and cotton too. Just like those tow straps, it will head south eventually. Hose gets tested around here once a year. I've seen failure in use, it's exciting and a hazard.
Hose removed from service can be handy, it is pretty tough stuff.
I agree IF they were used, but in most buildings the only abuse is dust from sitting on them.
   / Share Pics of People Hauling or Towing Something Wrong #11,447
I agree, hopefully the truck driver is not charged, certainly it was not the fault of the truck.
   / Share Pics of People Hauling or Towing Something Wrong #11,450
Doubt that its DOT legal but they sure but some effort into it.
I don't see what is wrong with that. I used to drive back and forth to New York with my ATV in the back of my Toyota, and the rear wheels resting on the tailgate. I'm trying to scrounge up some square tubing to make a bracket somewhat similar to the above for my snowsled to set on, I'm tired of pretzeling tailgates.
   / Share Pics of People Hauling or Towing Something Wrong #11,451
He’s got 2x12s spanning the bed to take most of the load off the tailgate. I don’t understand the point of the bracket. A strap would be far less effort than that.
   / Share Pics of People Hauling or Towing Something Wrong #11,452
It looks like he may also have one of those in front. Granted his bracket to the receiver is rather gumped together, but I unless his bolts loosen I can't see the wheeler going very far without the truck attached.
   / Share Pics of People Hauling or Towing Something Wrong #11,453
They make a very similar commercial mount for ATVs - Here is one at Bass Pro - Access Denied
   / Share Pics of People Hauling or Towing Something Wrong #11,454
I have seen an apparatus called guard dog to secure an atv in the back of a pickup. There are other makers also that are very similar with different names. I think even amazon sells a version or two. I agree with 4570Man that a couple of straps would get the job done for me.
   / Share Pics of People Hauling or Towing Something Wrong #11,456
Cinch down the front end with a strap or two and you're good to go from a moral standpoint. That contraption on the rear should easily (in a court of law) satisfy any National non-commercial tie down requirements.
   / Share Pics of People Hauling or Towing Something Wrong #11,457
Some well designed brackets like a rental stump grinder are a real time saver but the ATV can’t be loaded with this guys contraption in place. A strap would be way faster.
   / Share Pics of People Hauling or Towing Something Wrong #11,458
Some well designed brackets like a rental stump grinder are a real time saver but the ATV can稚 be loaded with this guys contraption in place. A strap would be way faster.
Overkill is the name of the game today.
Insure against anything that can happen less frequently then getting struck by lightning.
A solid steel connection holding the ATV in is better then flimsy straps that can stretch and or break.
You SHOULD use BOTH.
Anything else is putting MY family at risk of certain death even though we are in a different state.
   / Share Pics of People Hauling or Towing Something Wrong #11,459
I don't like straps for holding them down, although I use them with 1/2 inch nylon rope for backup. Last winter I was on a rough road and the only thing holding the snowsled on was a 3" rachet tie down; when I got to where I was going the only thing keeping it on was pure luck. I had cinched the sled up tight against the front of the bed, but because of the up and down motion on the bumps the strap came unhooked. I also need to get some of the fire hose which somebody else suggested, after a winter with the straps run through the suspension thry are marginally effective.
   / Share Pics of People Hauling or Towing Something Wrong #11,460
Securing equipment that have flexing suspension is always a bit different and more difficult. A variety of solutions are available. For instance when using chains, binders are made in different sizes that are spring loaded so that the chain stays tight even as the load moves up and down. Perhaps they would be of use.
Constant Tension Load Binder
Sterling 9500 (A61306)
Bulk Lot of over 600 NEW Motorcycle Sprockets - 1980s to Present (A61306)
Bulk Lot of over...
2004 FORD F-350 SUPER DUTY (INOPERABLE) (A58214)
2004 FORD F-350...
2013 HINO 338 26FT BOX TRUCK (A59905)
2013 HINO 338 26FT...
(APPROX. 20) 4' X 8' X 3/8" SHEETING (A52706)
(APPROX. 20) 4' X...
2020 PETERBILT 567 (A58214)
2020 PETERBILT 567...
