   / Share Pics of People Hauling or Towing Something Wrong #2,561
I think the ball is welded onto the square shaft, rather than bolted through it. Also, it looks from the way the bumper is dinged up that the hitch has already done considerable side-to-side swinging...imagine if they hooked up a trailer loaded with a too-light tongue; the set-up would look like a snake going down the road (and maybe into the ditch!).
That swinging must make backing up the trailer a fun event
   / Share Pics of People Hauling or Towing Something Wrong #2,563
There was a day when simple clip on bumper hitches were the norm! <img src="http://www.tractorbynet.com/forums/files/trailers-transportation/446041-share-pics-people-hauling-towing-image-jpeg"/><img src="http://www.tractorbynet.com/forums/files/trailers-transportation/446042-share-pics-people-hauling-towing-image-jpeg"/>
I think that was the same day they used real metal n lots of it for bumpers!
   / Share Pics of People Hauling or Towing Something Wrong #2,564
   / Share Pics of People Hauling or Towing Something Wrong #2,565
I had one also about fifty years ago. [the strap-on bumper hitch.]
I just bought the twin of this from a junk shop that liquidates estates. It likely is 50 years old.
I have a vague idea I can cut the curled end off the bumper strap, straighten the strap a little, then weld it to the back side of my loader bucket. Then I can curl the bucket forward to expose the ball, low enough to get under the trailer's hitch. Well something like that. I haven't gotten around to trying a layout yet.
   / Share Pics of People Hauling or Towing Something Wrong #2,566
Or epoxy it to the plastic bumper on your car :D
   / Share Pics of People Hauling or Towing Something Wrong #2,567
I just went to the basement and checked my chain clamp bumper hitch... 2,000 lbs tow rated with 200 lbs tongue max.
Just right for a 800 lbs aluminum fishing boat, outboard and trailer...
   / Share Pics of People Hauling or Towing Something Wrong #2,568
Your problem is solved, but I suspect this guy's problems are ongoing and not just in the hitch department.
The guy's greater problem is with Archimedes and the lever effect. Whatever his tongue weight is, it's multiplied by the effect of the "lever".
By the way, this double post thing is starting to go viral. Seems half my posts double.
2019 Freightliner M2 106 AWD Altec DM47BTR Insulated Digger Derrick Truck (A55973)
2019 Freightliner...
2010 Dodge Grand Caravan (A56859)
2010 Dodge Grand...
2018 CATERPILLAR 336F L (A58214)
2018 CATERPILLAR...
Adams 6T Fertilizer Spreader (A56435)
Adams 6T...
2018 Ford F-350 4x4 Ext. Cab Stellar FC3200 3,200lb 1.5 Ton Service Crane Truck (A55973)
2018 Ford F-350...
2017 John Deere HPX Gator Utility Cart (A56857)
2017 John Deere...
