   / Share Pics of People Hauling or Towing Something Wrong #22,401
lol... the debate over what constitutes a "boat" versus a "ship" has probably raged for more than 500 years, with every industry, culture, and even company having their own dividing line. The one I outlined above is supposedly used by the US Navy, at least according to one source I came across, but I am sure there are others.
Having heard many arguments on why one should be called one thing, versus the other, I actually think this is as good a way to distinguish them as any other I have heard.
Ah, they are all big gray boats in the danged Navy.
   / Share Pics of People Hauling or Towing Something Wrong #22,403
So called "truck driver " was fully equipped with flip flops too !
   / Share Pics of People Hauling or Towing Something Wrong #22,406
Yep, she's high centered just past the drive axles! Might have even taken the weight off the fifth wheel.
   / Share Pics of People Hauling or Towing Something Wrong #22,408
   / Share Pics of People Hauling or Towing Something Wrong #22,409
With the exception of ships made to transport ships.
Bruce
   / Share Pics of People Hauling or Towing Something Wrong #22,410
Easy to get it out of there. Pop the linkage off the leveling valve on the tractor rear suspension, hold the lever up so the suspension inflates raising the front of the trailer. drive it back to level ground and reinstall the leveling valve linkage. Even if you had to break the linkage, it would be cheaper to repair than the cost of a tow truck bill. Way back in my driving days, I helped a few guys out that way, two of them that were stuck in RR crossings. If the truck has spring suspension, you'll need a pull.
2013 Peterbilt 367 20Yd Ox Bodies Tri-Axle Dump Truck (A56858)
2013 Peterbilt 367...
Auger Drill Bit (A56857)
Auger Drill Bit...
2015 Lincoln MKZ Sedan (A56859)
2015 Lincoln MKZ...
LOT: Fuel Transfer Tank, Tool Box, 12 Volt Fill-Rite Pump (A59076)
LOT: Fuel Transfer...
2014 Transcraft DTL 3000 53ft. 50 Ton Tri Axle Drop Deck Equipment Trailer (A55973)
2014 Transcraft...
2013 POLAR TANK TRAILER CRUDE TRAILER (A58214)
2013 POLAR TANK...
