   / Share Pics of People Hauling or Towing Something Wrong #20,991
Back in the 60's in the Army, there were two versions of 6x6 truck chassis. IIRC, one had dual 9x20 tires and the other had single 11x20 tires. I was told the singles were for better off-road performance.
Bruce
Part of this is likely not getting rocks stuck between the duals
   / Share Pics of People Hauling or Towing Something Wrong #20,992
You want minimal PSI when on sand, your finding lower tire pressure helps is the very proof of that, and duals increase that potential lower range even more than singles, when on sand or snow. It has to be the fact that you've got floating duals in rear, while skinnies digging in up front, that is the confounding factor.
Never did bother with airing the tow vehicle down.
It was much quicker to leave in Drive, then hop in the Jeep and push it out. That was one (the only?) advantage of flat towing.
   / Share Pics of People Hauling or Towing Something Wrong #20,993
I've heard that called out before in off-road discussions that duals make things worse in sand. I don't know the 'why' of it, but it appears to be the case.
TrailMater does ok. Rory does better on the rock, but TrailMater and Ol' Blue do run in the sand.
He's more the exception than the rule though.
   / Share Pics of People Hauling or Towing Something Wrong #20,994
I worked in the mud for 29 years, the dual wheels on Ready Mix trucks were much better in mud than the single fat tires.
Don't remember about sand.
I operated a P&H 215 Crane mounted on a (CCC) Crane Corporation Company 10 wheel truck with front wheel drive.
I learned the best way to back up in sand was to pick a speed, 2/3 to full throttle and don't change the speed and it prevents
hopping.
   / Share Pics of People Hauling or Towing Something Wrong #20,995
It's actually super easy with one of those vehicles. Just shut the traction control off and have fun
The problem is that over 30 mph, GM products turn it back on again.
   / Share Pics of People Hauling or Towing Something Wrong #20,996
In the AF fire department our water tanker had dual rear axles with dual tires and all wheel drive, the crash trucks had dual rear wheel axles single tires all wheel drive.
These vehicles are heavy and the water tanker would go off road in sand or mud where the crash trucks could not go.
In fact the only time we almost got stuck in the tanker it would have taken a large bulldozer to haul it out.
   / Share Pics of People Hauling or Towing Something Wrong #20,997
There's more to it than if a vehicle has tandem axles and singles or tandems with duals. A lot of other things factor in.
When getting my M936, which should have duals, I specified 14R20 singles instead, knowing damn well that otherwise (at best) I'd leave deep tracks...or get stuck.
The seller recommended against it in a crane application for stability reasons, but when I explained that I'd rather deal with less lateral stability than getting 40,000 lbs. stuck, they agreed with my choice.
   / Share Pics of People Hauling or Towing Something Wrong #20,998
From discussions I've heard about it I don't think that's it at all. For some reason duals tend to dig themselves in faster in sand. I'm no expert and all I have to share is hearsay from folks who are 'experts', such as on Matt's Off Road Recovery who operate in those conditions all the time. But what I've heard from those folks contradicts this idea.
Carrying ability, especially off road on low air pressure, has little to with tire width, but with air volume.
We used to have a tractor on 12.4-36 tires, with add-on duals.
Our later one had 16.9-30 which are the same height, yet 50% wider. They had the same load capacity as the 12.4-36 on duals.
Also modern tractors, when you go over 200hp tractors dont use the wide ratio 650/65R42 anymore, but 650/85R38, higher sidewall gives more air volume, gives more flex, thereby a larger contact patch and more carrying capacity.
Single tires have high sidewalls, and therefor are better in bellying out over a large contact patch, by making contact to the ground over a longer length, without increasing the amound of mud the tire has to displace to get along.
Here in Holland we run dumptrucks on supersingles all around, even the fixed axle. 11.5 ton allowed when the axle has permanent drive and is more than 6 feet spaced from the next axle, with a max GVW of 50 ton.
When you create ruts, you have less resistance with all wheels in the same track. With a conventional 8x8 you run a track with your front axles, then your tandem duals push a new rut in the soil on both sides of the front axle rut. Displacing soil causes resistance.
Heres a Tatra 10x10 with a legal gross of 50 ton, in dredger sand. Since these became available, more and more people choose supersingles on dumptrucks.
   / Share Pics of People Hauling or Towing Something Wrong #20,999
In Detroit, the reason they were going to fat singles is that mud and rocks don't get jammed in between the duallies.
   / Share Pics of People Hauling or Towing Something Wrong #21,000
Another added benefit. When driving a dually in deep mud, it takes a quarter mile before the last mud is slung from between the duals. Nowadays with people sueing whenever they slide off the road during harvest season, (instead of driving careful) its an important argument for wide singles.
2021 UTILITY VS2DX 53FT DRY VAN (A59575)
2021 UTILITY VS2DX...
2002 CATERPILLAR D6M HIGH TRACK CRAWLER DOZER (A52709)
2002 CATERPILLAR...
2005 EZ-GO Utility Cart (A55851)
2005 EZ-GO Utility...
Caterpillar 262D3 (A57148)
Caterpillar 262D3...
Computerized Wheel Balancer (New/Unused) (A59225)
Computerized Wheel...
2025 YOU-380 Mini Skid Steer Loader (New/Unused) Includes Bucket and accepts multiple attachments (A59225)
2025 YOU-380 Mini...
