   / Share Pics of People Hauling or Towing Something Wrong #20,961
It's much more difficult with a newer vehicle equipped with TC and Stablitrak.
Thankfully, on the ones that have traction control I can turn it off.
One that bugs me is the Challenger GT AWD since it engages the front when the temp is 40 or below (among other avoidable things), which is generally every morning here for nine months or so of the year.
I've started looking at the wiring diagrams to find the best place to interrupt the system with a simple switch. It's possible that the newly acquired Durango has the same setup, but that's still unconfirmed.
Unlike the Challenger, there's nothing in the EVIC that tells me if the AWD is on or off. Might have to use AlfaOBD on that one to find out. At least I've managed to get rid of the the tiny battery for the stop/start function on it.
   / Share Pics of People Hauling or Towing Something Wrong #20,962
If it jumped of the hitch it would crush the bed sides, seen that a few time here. Most likely he unhooked did not pull clear before lowering the front or engaged auto level. That will dip the front of the trailer way down at the beginning of the level sequence.
   / Share Pics of People Hauling or Towing Something Wrong #20,963
He’s got a gooseneck adapter that might have held it up enough to save the bed sides.
   / Share Pics of People Hauling or Towing Something Wrong #20,964
Gooseneck would take a jolt to jump off (like going up steep bumpy hill) and is unlikely to happen in slow transport. Kingpin will slide out almost as soon as you start in most cases if not locked in.
I've seen both types loose a unit going up a hill on the way out of here. Gooseneck was never locked and the other the king pin lock engaged but did not lock (not maintained).
Almost 20 years at the park I've more way to screw up than you can imagine....many do it even when told they are about to destroy something.
I even had one forget to put nuts on his fifth wheel hitch mounting bolts. Well he had one installed, bent that hitch to holy hell. I took it to my shop and massaged it enough to work good enough to get the unit out of here to a shop.
   / Share Pics of People Hauling or Towing Something Wrong #20,965
I hope that Challenger handles better that my 80's AMC Eagle did. It was RWD with a viscous coupling to engage the front axle when F/R axle rpm's differed. First year version, the front axle couldn't be disengaged.
It was terrifying to put into a slide on a slippery gravel curve. You could control the radius perfectly but had no control over which way the nose would be pointed as you completed the curve. A disappointment after real 4x4's, Willys and Wagoneers, that could be controlled expertly and faster.
   / Share Pics of People Hauling or Towing Something Wrong #20,966
Haven't tried the AWD Challenger on gravel or dirt yet. but on pavement it's better at flinging around curves than the 6.2 Challenger is.
At first I credited the AWD, but now I'm relatively sure that it's due to the lower weight of the engine.
And I'm all for making whatever I want to work by moving the appropriate levers.
   / Share Pics of People Hauling or Towing Something Wrong #20,967
It's actually super easy with one of those vehicles. Just shut the traction control off and have fun
   / Share Pics of People Hauling or Towing Something Wrong #20,968
I like drifting. That's one reason I don't mind snow and ice.
Much easier to go sideways then, and it's doable at much lower speeds.
So do I.
The night before I became a father, we were sliding around corners and doing donuts in empty parking lots during a major snow storm.
We paid the price though. Soon after the fun was over we had to drive 25 miles in that blizzard to get to the hospital.
   / Share Pics of People Hauling or Towing Something Wrong #20,969
When I got my first vehicle with awd it snowed pretty hard over night.
Being curious how well it worked I went out to a mall parking lot with a friend.
I turned off the TC and started a slide. Told my friend to turn the TC on (button was middle of the dash) and I was amazed how quickly we went from a slide to straight where I had the wheels pointed.(y)
I have gotten stuck with AWD as it isn't 4 wheel drive. But in urban settings during the winter it makes for a much safer drive. You can't be an idiot obviously.
   / Share Pics of People Hauling or Towing Something Wrong #20,970
I actually have to shut my traction control off in my F550 service truck on a couple different jobsites. It's to get up steep gravely hills.
The traction control will actually stall the truck out and prevent me from getting up the steep grades. They aren't very long. But your crawling through an area and going slow to keep from tearing something up.
Then a sharp 90° turn and up this small but steep slope to get out.
If the traction control is engaged, it will limit the rpms and apply the brakes to the tire it deems to be slipping.
Between the two, the truck will get almost to the crest and just run out of juice with the go pedal pushed to the floor.
If I shut the traction control off, the tires will spin a bit here and there, but it will crawl right up the slope.
Granted, the service truck weighs 17,900 lbs.
2011 FREIGHTLINER CASCADIA TANDEM AXLE DAY CAB (A59575)
2011 FREIGHTLINER...
2017 VOLVO VNM SINGLE AXLE DAY CAB (A59575)
2017 VOLVO VNM...
2014 Peterbilt 377 Tandem Axle Reefer Truck (A55272)
2014 Peterbilt 377...
Lely 1250 3Pt. Fertilizer Spreader (A57149)
Lely 1250 3Pt...
Bobcat T590 (A53317)
2003 Sterling Tandem Axle Dump (A55272)
2003 Sterling...
