   / Share Pics of People Hauling or Towing Something Wrong #18,861
Cause i like to tow tongue heavy. With adjustable headlights, cops dont realise that i tow 7k when oncoming.
Well, that is what I said, Americans will put everything on the tongue they can. No matter it will tow much easier with a modest load on the tongue, they will never know for never trying.
Sure, install HD shocks and springs on the rear of a Subaru just to occasionally tow 2000 pounds! When properly balancing the trailer gets the job done without shocks, springs, or bandaids such as "weight" distributing hitches (which do not distribute any weight, only loads).
A load distributing hitch is useful with 8000 pound trailers on SuperDutys. But is a bandaid for many other situations.
When driving 500 mile days with my toy hauler I practiced moving the motorcycles inside for best tow. All the way to the front was not the best. I used bumper drop to guess at how much load was on the tongue, I know how much I weigh, how much the truck sagged under my weight, and then me and a friend, and guessed it would be approximately linear for greater loads.
   / Share Pics of People Hauling or Towing Something Wrong #18,862
I’ve never had any problems with the weight distribution on my tilt deck. Of course I can’t park my skid steer on the tail but there’s plenty of deck space to avoid that issue. Resting my trencher boom or tractor bushhog on the tail is no big deal.
And I see you haven't tried to park your load on the trailer as far forward as possible. By eye, it looks like you have a good balance of modestly favoring load to the front with sufficient to the rear.
   / Share Pics of People Hauling or Towing Something Wrong #18,863
Ive seen the local farm machinery manufacturer slide from their No.1 position in silage trailers. They used to build a very robust silage trailer in the 80s and 90s by using the next size up in C channel that their competitor used. But they stuck with the mindset of using big beams. An apprentice was once told to stop beveling square tubing for weld penetration, farmers want to see heavy welds in sight, and when its full penetration, farmers dont see that...
In the short term, bigger is better, but when products and manufacturers get time tested, proper engineering wins over sheer dimensions.
Made me wince. I cut my teeth at a drafting table working for Chicago Bridge & Iron. Every weld got bevels. CBI standards only permitted the most rudimentary weld symbols, all welds got a cross section drawing explicitly showing the bevels, depth, flat in the center, and a sacrificial pass in the center before the final pass outside and inside. Then again a 1" plate was thin for what we were doing.
About this time a platform collapsed in a hotel, in Missouri I believe. Revelers were dancing on a platform about the 3rd story that had another platform hanging from it on the 1st or 2nd above street level.
There were many construction goofs vs the architect's drawings. Square "tube" was made by welding two channels together. Simple surface weld, no beveling, certainly not full penetration. This failed, but might not have. The problem was something like a 40' rod was to be used, with a threaded section in the middle, the nut on these threads to hold the middle platform. A rod like that is crazy to procure, maybe get one threaded full length but 40'?
So without engineering approval the contractor purchased (2) 21' rods (for each of about 6 locations), threaded each end. Then put 2 holes through the now-square channel, right through the seams. One hole held the support rod from above, the other hole held the platform below. Now the square beam and it's lousy welds was carrying the load of 2 platforms. Nut pulled through, platform collapsed, killing many.
Had the contractor used a turnbuckle to extend the rod rather than use 2 holes in the beam he might have gotten away with it. The seams in the beam from making square out of two channels was also fishy.
   / Share Pics of People Hauling or Towing Something Wrong #18,864
That's a very odd generalization. While I'm sure there are some folks who think that way, that vast majority of people I know who tow are well aware of 10-15% tongue weight rule and at least attempt to honor it. I don't think I've ever encountered anyone whose mindset was "as much tongue weight as I can get".
   / Share Pics of People Hauling or Towing Something Wrong #18,866
Well, we have seen such posts here.
   / Share Pics of People Hauling or Towing Something Wrong #18,867
I design (among others) excavator chassis for high reach demolition rigs. Thickest flange i used so far was 4"
For booms we like full bevel on longitudinal welds too, just to avoid the fatigue crack initiation point in the root of a simple corner weld.
I know the case, it often appears on Discovery Channel s "Engineering disasters" "seconds from disaster" or anything such.
   / Share Pics of People Hauling or Towing Something Wrong #18,868
My trailer weighs 2000 pounds empty... :)
   / Share Pics of People Hauling or Towing Something Wrong #18,869
I think there is a pretty good percentage of people who tow with absolutely no clue……
Totally true, but the lack of clue doesn't mean they migrate towards "all the tongue weight I can get". My statement is about the lack of experience I've seen justifying that generalization.
   / Share Pics of People Hauling or Towing Something Wrong #18,870
And this is a tiny microcosm of America. Have you encountered a lot of people in real life that "love them a lot of tongue weight"?
2015 CATERPILLAR D6N LGP HIGH TRACK CRAWLER DOZER (A52709)
2015 CATERPILLAR...
Pallet of UV Solid Hardwood Flooring (A55758)
Pallet of UV Solid...
INGERSOLL RAND  G25 GENERATOR (A58216)
INGERSOLL RAND...
2010 LAREDO 5TH WHEEL (A55745)
2010 LAREDO 5TH...
backhoe attachment for full size skid steer (A56857)
backhoe attachment...
Butterfly Artwork (A55758)
Butterfly Artwork...
