   / Share Pics of People Hauling or Towing Something Wrong #13,591
   / Share Pics of People Hauling or Towing Something Wrong #13,592
That was the premise of the movie 'All Is Lost'. Robert Redford is single handing a boat and finds a partially submerged container the hard way.
I have owned several containers,,
the first one I purchased (in 2001, used) was made out of COR-TEN steel.
There was a sign inside that container instructed that repairs could only be done using COR-TEN steel to maintain the container strength.
Now, the one-way ,, or relatively disposable containers are made out of the same steel as a Campbell's soup can.
COR-TEN is crazy strong,, compared to A36 (every day, steel that we get cheap, like angle "iron" , and sheet hot rolled, etc,,)
How much do you want to bet that container losses will continue to get worse, now that low strength steel is being used for container fabrication??
I would bet that no one gave a thought to the fact that the containers are significantly weaker,,
The floors used to be tongue and groove hardwood, like flooring in a house.
Now the flooring looks like plywood made out of bamboo,, :eek:
   / Share Pics of People Hauling or Towing Something Wrong #13,593
I saw that movie a while back, thought it was pretty good.
   / Share Pics of People Hauling or Towing Something Wrong #13,594
   / Share Pics of People Hauling or Towing Something Wrong #13,595
When I used to move heavy equipment at the family construction company, I had a folding stick that had an arm on it at 13' 6" high to check loads that looked anywhere near over height. Over the years, a few fooled me and were higher than they looked. Another driver was moving our Marion dragline crane through town and had the boom end hit a traffic signal right on Main Street. Dad was not happy about that. With all 55' of boom on it with the boom out over the truck cab, you had to almost rest the boom on the headache rack to keep it under 13' 6". When I could, I would haul it out the back, but then I was 110' long, and our OD permit was only good for 70'. I only got busted once, and the cop let me turn it so it was out the front, and only gave me a warning.
Another construction company had an Allis Chalmers HD21 dozer that I moved for them occasionally. I alwas hated moving that big beast, it was right at the rating of our Talbert lowboy trailer of 35 tons. With it on our truck and trailer, it grossed out at almost 110,000#, on 5 axles. That made the 6-71 Detroit in the tractor grunt.
Here's another example of driver stupidity.
   / Share Pics of People Hauling or Towing Something Wrong #13,596
The interesting thing I have noticed when you see a coil setting on a broken trailer is that almost every one is an aluminum trailer. The picture in my post #13535 of the broken trailer was an aluminum trailer also. Of course, probably over half of the flatbeds in use now are aluminum trailers.
A metallurgist friend once told me, and showed me a chart, that aluminum is much more prone to fatigue failures than are ferrous metals. Once it begins to fail, it's integrity is compromised, and it takes less and less stress for it to fail catastrophically. Steel ir much more ductile and will deform repeatedly, and not lose a lot of strength before it finally fails. That's why you will see steel frame flatbeds that are swaybacked from overloading, but not aluminum trailers. once they are overstressed and a crack develops in the structure, it's all over pretty quickly. ****, I even had a steel trailer back in the 70's that a welder friend re-arched the frame by heating the beams with a big rosebud torch. It went from a couple of inches of sag to about three inches of bow. I owned it for a couple of years after that and it still had bow in it when I sold it.
Looking more closely at the picture, I see that there is a toolbox crushed right at where the frame broke. It very possible that whoever installed the toolbox mounts drilled holes in the web, then used steel bolts to attach them. Over the years dissimilar metal corrosion may have started stress risers in the web. I doubt anyone is stupid enough to drill holes in the beam flange, but who knows? I always suspended my toolboxes from the crossmembers instead of drilling holes in the frame web. Better to have to repair a crossmember than have the frame fail.
I'm sure that trailer is junk, I can't imagine a way to fix the beams that would be safe. Welding it would only weaken it more. Nope, he's going to need a new trailer.
I'll bet that Kenworth came to a stop pretty fast when the frame hit the pavement. Probably got a good jolt when he crossed the RR tracks, and that was just enough to make it fail. I feel sorry for the guy, but when you haul those big coils on long trailers, especially aluminum trailers, you're taking a chance on damaging the structure.
He had it secured properly though, as it's still chained fast, so the cop can't ticket him for an unsecured load.
Aluminium has no fatigue limit, (stress which you can put to it without fatigue accumulating) where steel has one. Not that it matters much, because most constructions are loaded above the fatigue limit for weight reasons.
   / Share Pics of People Hauling or Towing Something Wrong #13,597
Cor-ten is the same tensile stren strength as normal machine steel, the difference is that it creates a rust layer that is **** off fron oxygen so it doesnt rust through, just like aluminium.
   / Share Pics of People Hauling or Towing Something Wrong #13,599
   / Share Pics of People Hauling or Towing Something Wrong #13,600
BB1aCT9r.img
11/2/2020
BRISTOL, CT (WFSB) - Bristol police are investigating the attempted theft of an ATM.
Police said the driver of a black Jeep Wrangler that was reported stolen from Bloomfield was found by a patrol officer to be dragging a People's United Bank ATM behind the vehicle.
Some people just ain't got a whole lot in the smarts department.
(2) TRACTOR TIRES (A54757)
(2) TRACTOR TIRES...
2015 DODGE RAM 4500 HD SERVICE TRUC (A54756)
2015 DODGE RAM...
2019 Ford F-550 4x4 Ext. Cab Chipper Truck (A51692)
2019 Ford F-550...
2006 Chevrolet Silverado 1500 4x4 Pickup Truck (A53422)
2006 Chevrolet...
Badger Silage Wagon (A50775)
Badger Silage...
UNUSED WOLVERINE PFA-11-3300G HYD PALLET FORKS (A54757)
UNUSED WOLVERINE...
