   / Share Pics of People Hauling or Towing Something Wrong #12,401
If it's like it looks (a 4wd pickup locked into 4wd with the rear driveline disconnected), it should hold up as long as it's not abused.
Aaron Z
The front end wasn’t meant to continuously pull the entire vehicle plus a load.
   / Share Pics of People Hauling or Towing Something Wrong #12,402
I'm no mechanic... Is there a way to switch the rear drive train to the front? This guy had no problem going up some steep inclines.
   / Share Pics of People Hauling or Towing Something Wrong #12,403
Don't they do that sort of thing for some special rigs for moving airplanes around? I seem to recall pictures that had something to do with seaplanes and 4wd trucks with only front axles. But I think those are for yard use only, not freeway.
   / Share Pics of People Hauling or Towing Something Wrong #12,404
It wouldn’t make any difference to the motor and transmission . I’d worry about the durability of the front axle and associated parts. You can get a heavier one but no the rear axle can’t be used on the front because it doesn’t steer.
   / Share Pics of People Hauling or Towing Something Wrong #12,405
The drive chain in the transfer case is not strong enough either.
   / Share Pics of People Hauling or Towing Something Wrong #12,406
I doubt it has very good brakes either. They were probably barely adequate to start with and he took off one axle.
   / Share Pics of People Hauling or Towing Something Wrong #12,407
   / Share Pics of People Hauling or Towing Something Wrong #12,408
Around here the Riviera chassis was popular for floatplane tugs. Later the K-Cars were used a lot.
   / Share Pics of People Hauling or Towing Something Wrong #12,409
   / Share Pics of People Hauling or Towing Something Wrong #12,410
Man, this takes the cake...towing a long singlewide trailer with a pickup on small country roads....around corners??????!!!!!!!!!!! PS...warning....smoking trucks, tempers, and broken drive shafts will be seen.
These pickups towing a single wide is the wildest thing you'll see on the internet today
The best part: "Update theyæ±*e still out there trying to pull it. Also apparently the guy pulling the trailer originally in the video only has 1 leg and the Cummins is a manual"
Also, it appears to be a dove tail single wide. :laughing:
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2010 International 4300 TMA Attenuator Truck (A55973)
2010 International...
PALLET OF MISC (A58374)
PALLET OF MISC...
2013 Chevrolet Silverado 3500HD Enclosed Service Truck (A55973)
2013 Chevrolet...
2015 Jeep Cherokee Latitude SUV (A55758)
2015 Jeep Cherokee...
LOT: Uline 72" Rolling Staircase, 6' Fiberglass Stepladder (A59076)
LOT: Uline 72"...
