   / Share Pics of People Hauling or Towing Something Wrong #12,401
If it's like it looks (a 4wd pickup locked into 4wd with the rear driveline disconnected), it should hold up as long as it's not abused.
Aaron Z
The front end wasn’t meant to continuously pull the entire vehicle plus a load.
   / Share Pics of People Hauling or Towing Something Wrong #12,402
I'm no mechanic... Is there a way to switch the rear drive train to the front? This guy had no problem going up some steep inclines.
   / Share Pics of People Hauling or Towing Something Wrong #12,403
Don't they do that sort of thing for some special rigs for moving airplanes around? I seem to recall pictures that had something to do with seaplanes and 4wd trucks with only front axles. But I think those are for yard use only, not freeway.
   / Share Pics of People Hauling or Towing Something Wrong #12,404
It wouldn’t make any difference to the motor and transmission . I’d worry about the durability of the front axle and associated parts. You can get a heavier one but no the rear axle can’t be used on the front because it doesn’t steer.
   / Share Pics of People Hauling or Towing Something Wrong #12,405
The drive chain in the transfer case is not strong enough either.
   / Share Pics of People Hauling or Towing Something Wrong #12,406
I doubt it has very good brakes either. They were probably barely adequate to start with and he took off one axle.
   / Share Pics of People Hauling or Towing Something Wrong #12,407
   / Share Pics of People Hauling or Towing Something Wrong #12,408
Around here the Riviera chassis was popular for floatplane tugs. Later the K-Cars were used a lot.
   / Share Pics of People Hauling or Towing Something Wrong #12,409
   / Share Pics of People Hauling or Towing Something Wrong #12,410
Man, this takes the cake...towing a long singlewide trailer with a pickup on small country roads....around corners??????!!!!!!!!!!! PS...warning....smoking trucks, tempers, and broken drive shafts will be seen.
These pickups towing a single wide is the wildest thing you'll see on the internet today
The best part: "Update theyæ±*e still out there trying to pull it. Also apparently the guy pulling the trailer originally in the video only has 1 leg and the Cummins is a manual"
Also, it appears to be a dove tail single wide. :laughing:
Sterling T/A Ox Bodies 16Yd Dump Truck (A56858)
Sterling T/A Ox...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A56436)
2019 Krause...
UNUSED 89" LAND PLANE (A52706)
UNUSED 89" LAND...
5-6 YD BLUE LINE GRIZZLY SCREENER (A58214)
5-6 YD BLUE LINE...
2004 John Deere 310G 4x4 Loader Backhoe (A56857)
2004 John Deere...
2003 Walk-Behind Automatic Seed Spreader (A55851)
2003 Walk-Behind...
