Shan Dong / Tashan Tractor
/ Shan Dong / Tashan Tractor #21
Hi Kidney
The supply is all under the seat
Thanks Bob
/ Shan Dong / Tashan Tractor #22
Hi Greg
Why do I have to stop to put the PTO in gear?
You have to stop to put the PTO in gear because - just like the transmission - there are no synchros.
Why do I have to have the PTO in gear to raise or lower the bush hog?
The main hydraulics (rear lift, front loader, etc) are powered by a PTO pump. No PTO, no hydraulics. Hydraulic steering is powered by a second (engine driven) pump.
//greg//
/ Shan Dong / Tashan Tractor #23
Then what is a 2 stage cluch, and what does it do?
Thanks Bob
/ Shan Dong / Tashan Tractor #24
It's basically two inline clutches that drive two separate shafts, all housed in a single clutchpack. When you kick in the clutch, the 1st half of pedal travel disengages the main drive clutch. The tractor stops moving, but the PTO - if otherwise engaged - is still turning. The 2nd half of the pedal travel disengages the PTO clutch. Conversely, when you let up on the clutch pedal 1/2 way, only the PTO clutch gets engaged. Letting it out the 2nd half of its travel is what gets the tractor moving
//greg//
/ Shan Dong / Tashan Tractor #25
Hi Rob
So are you saying that I should be able to raise my 3ph with the tractor just seting and runing and PTO not in gear?
Thanks Bob
Hi Bob,
Looks like Greg answered you question.
He said you have a PTO driven pump that powers all your hydraulics except power steering. On my tractors, a Kama and a Jinma, there are 2 engine driven hydraulic pumps. One is for the power steering and the other is for all the other hydraulics. So on my tractors, all the hydraulics function all the time whether the PTO is engaged or not.
The 2 stage clutch needs a little getting used to.
On occasion, I still have the tendency to fully depress the clutch pedal while I am running a PTO driven implement. Which of course disengages the PTO. It took me a little while to get used to only having to depress the pedal half way to shift gears or stop the tractor while leaving the PTO running, such as for a brush hog.
/ Shan Dong / Tashan Tractor #26
Hello
I am new to the Group. I just purchased a none running tractor like the one pictures. Where can i get parts and manuals for it. I noticed with the tractor in gear and pulling it the fan nor the flywheel is turning.
/ Shan Dong / Tashan Tractor #27
/ Shan Dong / Tashan Tractor #29
I have a 1992 ts295t tiashan 25 2cyl and I need to know what temp the engine suppose to runand what temp the thermostat is suppose to be, any body know//
/ Shan Dong / Tashan Tractor #30
how come I cant get an answer to my question?
/ Shan Dong / Tashan Tractor #31
Personally I don't know your answer but I'd guess a 160 degree t-stat should be about it.
In answer to your question about why no one answers. - Most likely due to lack of knowledge on your product. And if you don't have any manual or anything on it considering it's a 1992 then you are probably out of luck just because a lot of folks have moved on from Chinese tractors in general.
Good luck,
Steve - no more Chinese for me either. Sent the Jinma/FarmPro down the road this week.
/ Shan Dong / Tashan Tractor #32
/ Shan Dong / Tashan Tractor #33
Does anyone know where i can find a 295t engine
2011 TRAIL KING INDUSTRIES PNEUMATIC TRAILER (A60736)
2011 TRAIL KING...
2013 FREIGHTLINER Cascadia (A63689)
2013 FREIGHTLINER...
1997 Fontaine 48Ft Flatbed Trailer (A64194)
1997 Fontaine 48Ft...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2016 Etnyre Falcon Live Bottom Trailer (A62613)
2016 Etnyre Falcon...
