Shan Dong / Tashan Tractor
/ Shan Dong / Tashan Tractor #1
DDMattox
Does anyone Have any info on a Shan Dong Tractor Works Tractor ? The Model is a Tashan 25. I Recently Aquired one and need a few parts even thought the Tractor Runs okay
Thanks for any help
/ Shan Dong / Tashan Tractor #2
(from the web)
“…Shandong Worldbest Shantuo Co.,Ltd. is one of branch companies of Worldbest Kama Machinery Co.,Ltd.("Worldbest Kama"), located at Yanzhou, one of the nine ancient Zhous of China in vicinity to Qufu, Confucian's hometown. It is the largest base of medium size tractors in China with the annual output 25,000sets tractors which cover 60% of domestic market among same line tractors and export over 30 countries and regions.
As an important affiliated enterprise, Shandong Tractor Works-the key manufacturer of China agriculitural machinery industry, jointed to set up the Worldbest Kama. With advanced workman design, strong technology, complete working equipments and test measures and perfect quality control system, the TS brand(Taishan)series tractors and Feidong brand(FD)series diesel engines produced by Shandong Worldbest Shantuo Co.,Ltd. and Shandong Tractor Works are sold well in domestic and international markets by super quality and international markets by super quality and reasonable prices with high reputation. Now, the mass production capacity of loaders, forklifts, other engineering mahinery and implements have been established in the enterprise.
Model TS250 tractors and Model FD295 diesel engines all won the prize of National Super Quality Products. Taishan brand Model 120,180,200,280,300,400,450series tractors and Feidong brand Model 295,52100 series diesel engines are the main products of enterprise, which have the characteristics of compact structure, easy operating, easy maintenance, lower fuel consumption, parts interchangable and multipurpose using. With top quality products, perfect servise a visionary managment and cutting-edge efficiency, the enterprise is ready to meet the customers requests and lead the way in the modernization of China agricultural industry." “
Shandong Worldbest Shantuo Co.,Ltd…
“For different purposes,Taishan 25HP series tractors are divided into:TS25A(Normal type),TS25K(High speed type),TS25Y(Transport type),TS25KS(For paddy fields),TS25-1(2-Stage clutch),TS25-2(2-Stage clutch and Creeper),TS25-4(Narrow wheel tread),TS254(4-wheel drive),TS254-1(4-wheel drive,2-stage clutch) and TS254-2(4-wheel drive,2-stage clutch and creeper).Besides these,Differential,Combined meter,Roll Bar,Hydraulic assistant steering,Wide wheel tread can be chosen by the users. “
Main Technical Data of Taishan 25HP series Tractors
shantuo@tstractor.com
/ Shan Dong / Tashan Tractor #3
hi,
I may be placing an order for some of these. I'd sure like your honest opinion of the tractor from a users point of view, either privately or here.
Also, it may be that I can get some parts ordered along with mine, but it will likely be 60 to 90 days away. What parts are you looking for?
Have you also posted on CTOA? Maybe someone there who can help sooner.
The Tractor I have Runs Well The bigest complaint I have is that mine is a single Stage clutch which should be no problem for Bush Hogging With the addition of an over run cluych But there is No hole thru the PTO shaft to attach the clutch and its a real Pain to install the Hole while its attached to the tractor. The parts i need are Wear Items such as filters and a few gaskets. Are there any Dealers presently in the US? The Tractor seems to be a good Piece of equipment This one is a 98 Model.
Thanks,
David
/ Shan Dong / Tashan Tractor #5
I am a Kama dealer and can get your parts. You can purchase a quick connect overrunning clutch that doesn’t need a hole through the PTO shaft. Give me a call we can talk about it
Buck
/ Shan Dong / Tashan Tractor #6
I have a quick connect, like Buck is talking about. It works great, and you can take it off easily when you don't want to use it.
/ Shan Dong / Tashan Tractor #7
Does anyone know where I can but a water pump for a Taishan TS-254 tractor?
Thanks
Rick
/ Shan Dong / Tashan Tractor #8
Thanks
Rick
TaiShan is a baby KAMA. As such, any KAMA dealer should be able to help ya out
//greg//
/ Shan Dong / Tashan Tractor #10
Hi Rick
Was you able to get a water pump?
If so where at and the amount.
Thanks Bob
/ Shan Dong / Tashan Tractor #11
... water pump? If so where at and the amount.
Can't tell from your photo Bob, two cylinder or three? Some older ones came with the TY295 thumper, newer ones have the Y385.
//greg//
/ Shan Dong / Tashan Tractor #12
Hi Greg
It is a two cylinder I need a water pump
and a few other items
Take care Bob
/ Shan Dong / Tashan Tractor #14
The Taishans made by Shandong tractor works have engines made in house, maked SD295 or SD2100. We have a couple of the water pumps for the 2 cyl in stock.
/ Shan Dong / Tashan Tractor #15
Hi Group
I have a Tashan 254 and am very lost on the post from DD Mattox. I have a single stage cluch also.Is there some way to make it a two stage?
Thanks for your input
Bob
/ Shan Dong / Tashan Tractor #16
Hi Group
Bob
What makes you think it's NOT a two-stage clutch?
//greg//
/ Shan Dong / Tashan Tractor #17
Hi Greg
Why do I have to stop to put the PTO in gear?
Why do I have to have the PTO in gear to raise
or lower the bush hog?
Thanks Bob
/ Shan Dong / Tashan Tractor #18
Hi Bob, and welcome to TBN.
I'm pretty sure the Taishan 254 is a 2 stage clutch.
With that in mind, stopping to put the PTO in gear would be normal operating technique. In order to disengage the PTO clutch, you press the foot pedal "past" where the first stage would disengage...all the way down. In other words, if you only depressed the pedal half way, you are only disengaging the first stage clutch ... your drive train. The PTO clutch would remain engaged at the 1/2 way mark, but the tractor would stop. To disenge the PTO clutch would require completely depressing the clutch pedal all the way down, which disengages both clutches.
Why do I have to have the PTO in gear to raise or lower the bush hog?
This I don't understand.
Raising or lowering the bush hog is done by the 3pt, right? So it would have nothing to do with having the PTO in gear.
Maybe I am missing your meaning?
Rob-
/ Shan Dong / Tashan Tractor #19
I think the pump for the 3 pt. hitch is driven off the pto gears. Is your pump mounted to the rear of the tractor over the pto? If that is the case the pto must be running for the 3 pt. lift to work.
kidney
/ Shan Dong / Tashan Tractor #20
Hi Rob
So are you saying that I should be able to raise my 3ph with the tractor just seting and runing and PTO not in gear?
Thanks Bob
2022 New Holland C327 Compact Track Loader (A63689)
2022 New Holland...
2025 Quick Hitch Skid Steer Attachment (A61572)
2025 Quick Hitch...
UNUSED WOLVERINE HYD BRUSH CUTTER (A64281)
UNUSED WOLVERINE...
2008 21 Ft. Sea-Doo Speedster Boat with 2008 22Ft. Karavan S/A Trailer. (A61574)
2008 21 Ft...
2014 Hyundai Sonata Hybrid Sedan (A61574)
2014 Hyundai...
UNUSED AGT YC-32G SAWMILL (A64281)
UNUSED AGT YC-32G...
