Shallow Well Pump for Gardem Water
   / Shallow Well Pump for Gardem Water #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I want to run a 110volt shallow well pump for garden and watering. Hoping to find a submersible like people use in deep cased wells, but this well is only 15 feet deep. Any recommendations on this type of 110Volt pump?
rScotty
   / Shallow Well Pump for Gardem Water #3
Not much margin for error at only 15’. Id make sure you you have a safety Incase it runs dry.
   / Shallow Well Pump for Gardem Water #4
I have a hand dug well that I just used a 1/4-1/3 hp sump pump with the garden hose fitting. I used this for filling a storage tank at the house. Worked well for 30 years. Now, I have removed the tank and have mounted a Grundfos pump out at the well to push the water and charge my system.
   / Shallow Well Pump for Gardem Water #5
I would recommend a Grundfos also. Be certain you have some form of "run dry" protection. Pumps do not come cheap.
   / Shallow Well Pump for Gardem Water #6
Goulds makes a good pump.
I have heard good things about Grundfos but never owned one . I have had a couple Goulds and they have been excellent .
The brand I won't buy because of previous experience(s) with them is Myers , yet some people I know have had good "luck" with them .
2020 Peterbilt 520 Truck (A51692)
2020 Peterbilt 520...
Adams 8 Ton Weigh Hopper (A52748)
Adams 8 Ton Weigh...
PORTABLE INDUCTION HEATER (A52472)
PORTABLE INDUCTION...
Wanco 800W Solar Integrator Trailer (A51691)
Wanco 800W Solar...
2012 Nissan Rogue SUV (A50324)
2012 Nissan Rogue...
377720 (A51572)
377720 (A51572)
