Shallow Well Pump for Gardem Water
   / Shallow Well Pump for Gardem Water #1
rScotty
Super Member
Rural mountains - Colorado
Kubota M59, JD530, JD310SG. Restoring Yanmar YM165D
I want to run a 110volt shallow well pump for garden and watering. Hoping to find a submersible like people use in deep cased wells, but this well is only 15 feet deep. Any recommendations on this type of 110Volt pump?
rScotty
   / Shallow Well Pump for Gardem Water #3
Not much margin for error at only 15’. Id make sure you you have a safety Incase it runs dry.
   / Shallow Well Pump for Gardem Water #4
I have a hand dug well that I just used a 1/4-1/3 hp sump pump with the garden hose fitting. I used this for filling a storage tank at the house. Worked well for 30 years. Now, I have removed the tank and have mounted a Grundfos pump out at the well to push the water and charge my system.
   / Shallow Well Pump for Gardem Water #5
I would recommend a Grundfos also. Be certain you have some form of "run dry" protection. Pumps do not come cheap.
   / Shallow Well Pump for Gardem Water #6
Goulds makes a good pump.
I have heard good things about Grundfos but never owned one . I have had a couple Goulds and they have been excellent .
The brand I won't buy because of previous experience(s) with them is Myers , yet some people I know have had good "luck" with them .
2016 PETERBILT 579 TANDEM AXLE SLEEPER (A51219)
2016 PETERBILT 579...
2007 WESTERN STAR 4900 (A50854)
2007 WESTERN STAR...
2018 INTERNATIONAL 4400 4X2 EXT CAB SERVICE TRUCK (A51406)
2018 INTERNATIONAL...
2020 PETERBILT 337 BOX TRUCK (A51222)
2020 PETERBILT 337...
Unused 2025 CFG MX20R Mini Excavator (A49461)
Unused 2025 CFG...
2019 CATERPILLAR 308 CR EXCAVATOR (A50458)
2019 CATERPILLAR...
