SHALLOW ROCKY TILLING
/ SHALLOW ROCKY TILLING #1
flINTLOCK
Platinum Member
PA
NH TC40DA 2002
I'm starting several food plots in rocky ground. I don't think I'd have much luck with a tiller and was planning to much of the ground busting with a disc. Any other attachment that could be used like a surface plow, only going 3-4 inches deep. I thought of a box blade with it's adjustable teeth. A york rake wouldn't get deep enough.
/ SHALLOW ROCKY TILLING #2
Ive used a box blade before as you mentioned and it worked well. I worked it in a crosshatched pattern and pulled an amazing number of rocks out. Some were too big for the tractor and blade to pull out though. I did this before I ran a tiller over the area. I think it save a fair amt of wear on the tiller.
/ SHALLOW ROCKY TILLING #3
I would go with a regular turning plow but plow shallow if you only want the top couple inches. If you are planning for behind a 30 horse tractor a 2 bottom Ford or Ferguson plow would suit you well and can be found all over for $2-$300 for good plows. At least in my part of the country this is what they are selling for.
Does the box blade have skids to keep blade on the surface??
/ SHALLOW ROCKY TILLING #5
No skids...just set the teeth all the way down and use the 3pt to adjust the depth...thats how I did it.
2016 Ford Explorer AWD SUV (A61569)
2016 Ford Explorer...
2018 VOLVO VNL TANDEM AXLE DAY CAB (A59912)
2018 VOLVO VNL...
2015 PALMER MACHINE WORKS 24' DUMP TRAILER (A60430)
2015 PALMER...
72"Skid Steer 4 in1Bucket (A62613)
72"Skid Steer 4...
2025 Mower King SSVR72 Hydraulic Vibratory Roller Skid Steer Attachment (A61572)
2025 Mower King...
Toyota 2FGC20 4,000lb. Propane Forklift. (A61572)
Toyota 2FGC20...
