3-Point Hitch Setup Yanny 1500d
/ Setup Yanny 1500d #1
relhogh
Florida
Yanmar 1500d
I am having trouble stabilizing the load on my 3 point hitch.
The lower arms hit the rear wheels.
I tried to use chains but the only place I had to hook them to was the large clevis below the PTO and then to the bottom of the lift links on the lower arms.
I tried to keep as much slack out of the chain as possible and when I raised the carryall it popped the hooks on the chains.(I guess the chains don't stretch).
Does anyone have clear pictures of what kind of setup is needed to solve my problem?
Any help appreciated.
Freezing in Florida
/ Setup Yanny 1500d
Winston
Thanks for your reply.
My setup has the stabilizers. but I don't see how they can be adjusted.
I seem to have a lot of play on the pin where the lower links and the stabilizers are swung. I have all the spacers shown in the parts diagram.
The elongation in the stabilizers slide over a pin and the nut is welded in place.
Thanks again:thumbsup:
/ Setup Yanny 1500d #4
Someone who owns a 1500 may have to chime in here. Just looking at the parts drawing made me think you could tighten #35 (nut) at any postition. If the nut is welded I don't see the need for the spring pin #33. I would think it was there to keep the nut from coming off in case it loosened. Just rattling, don't have a good answer.
/ Setup Yanny 1500d
Thanks again Winston1
I appreciate your trying to help.
I would like someone with photos of their setup to post to see if they had the same trouble.
Keep on rambling, you were trying.
/ Setup Yanny 1500d #6
my 1500 even full spread wont hit the tyres but mine are wide set. do you have the bracket numbered 30 on yours and are they bolted to the arms? mine sways around a fair bit because the bottom pin and all the arms/brackets are flogged out. i will fix all this one day and install some chains with turnbuckles to keep everything tight. i still have to make that quickhitch........:cool:
/ Setup Yanny 1500d #7
Not sure if you have done this already.... But are the rear tires flipped? I realize this doesn't resolve the issue as to why the tires are hitting the lift arms in the first place, Although by flipping them would give it a couple more inches of clearance on each side,;)
/ Setup Yanny 1500d
:thumbsup:Thanks Neat and Deep:thumbsup:
I do have item 30 bolted to the lower links.but they are allowed to slide in the elongated holes. the nuts are welded to the stud and cannot be removed.
I only use a CarryAll on the 3pt and the pins point out, about 30 inches apart. I tried to turn them in but then the lower arms don't have enough room inside the angle iron to be able to go over the pins.
Yes me Rear tires are reversed. I live on a hill and have to be VERY careful not to turn over.Thats the main reason I got the CarryAll, for the extra weight. I only use the FEL.
/ Setup Yanny 1500d #9
Those bars are not very user friendly. I have several customers that have just replaced them with the chains that are used on every single other Yanmar model --
Yanmar Tractor Parts: SWAY CHAIN (STABILIZER CHAIN)
You may have to customize things a little bit but once you get them working it will make adjustments much easier.
/ Setup Yanny 1500d
Aaron
Do you have a picture of the chain hookup on a Yanmar?
Thanks for the post.:thumbsup:
/ Setup Yanny 1500d #12
Relhogh, take a look at the photos I put in
this thread.
Combined with Hoye's diagram and their photo of their sway chain kit, you should get a good idea of how the sway chains are installed on most Yanmars.
/ Setup Yanny 1500d
Thanks to Everyone for the help.
I've got a good idea of what I need to do.
Start this weekend.(weather permitting):thumbsup::):D
/ Setup Yanny 1500d
Cal,
In your photos of the before and after.
Is the bracket that you attached the chain to a standard item?
The one that mounts on the pin with the lower link.
/ Setup Yanny 1500d #15
Cal,
Yes, the black bracket and everything painted black are original so far as I know. The bright cadmium-plated sway chain components are recent replacement parts.
I think Aaron (@Hoye) was pointing out you will need to buy from him two of the 'SCA-350' brackets shown in his most recent post, in addition to two standard sway chain assemblies.
/ Setup Yanny 1500d #16
Am I missing something? Aarons drawing seems to shown the chains crossing to the oppisite side lower lift arm? California, yours seems to be hooking to the same side lower lift arm?
/ Setup Yanny 1500d #17
As long as you have somewhere to attach the chains on the lift arm side you can. The tractor in my illustration (YM1510) does not have anything to attach to.
Just keep in mind that the closer to parallel the chains and arms are - the harder it is for the chains to keep the arms from swinging and more stress is put on the chains.
2018 MAGNUS MINI VAC TRAILER (A67714)
2018 MAGNUS MINI...
1989 Fontaine Flatbed Trailer (A64912)
1989 Fontaine...
John Deere TX Gator (A64912)
John Deere TX...
2010 Ford Expedition LTD (A64911)
2010 Ford...
2021 CHEVROLET TAHOE (A66091)
2021 CHEVROLET...
Kubota 76" QA Bucket (A64912)
Kubota 76" QA...
