Servis-Rhino TW72 (1999 model) Gearbox Grease
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #1
MUDONTHETIRES
Northern Louisiana
Mahindra 6065 4WD
Hello all,
The recommended lubricant is NLGI-000 such as Mobil EP023 for the gearbox. Would Lucas 84W-140 work as an alternative?
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #2
I tend to think 85W140 gear oil (even if it is a synthetic) would be a poor substitute for a semi fluid grease such as Mobil’s EP 023 (Mobilux EP 023 is a high performance special-duty semi-fluid greases. This lithium hydroxystearate grease is...)
Thanks so much!
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #6
Not a lube question but perhaps you can help me
I have a Rhino TW72 bought it used
Originally it was owned by a Cemetery (must have been in the foot hills as it has a few scars I would guess from large rocks???
I have a slip clutch on the the drive shaft. It works great on large stuff up to about 4" or a little bigger. But when I cut tall thick grass it cuts it, but leaves some of it a bit tall some after a single pass may be 12 to 16 " high it's usually a strip on I think the right side of the gear drive. Is this typical of this mower? I have a smaller lighter mower 48" which leaves a nicer cut. I was wondering if something is bent on the mower yoke or blades ? Or is this typical for this mower. I do have a flail mower, but I have some old tree branches remnants lying in the fields and don't want to damage the flail. Once I get the fields cleaned of debris, I will use the Flail, Thanks for any help..........
2017 Ford F-550 (A55973)
2017 Ford F-550...
2010 Freightliner Derrick Digger (A55973)
2010 Freightliner...
Black Metal Roof Panels (A55758)
Black Metal Roof...
2012 International WorkStar 7500 Vactor 2100 Plus Combination Sewer Jetter Vacuum Truck (A55973)
2012 International...
2018 DODGE RAM 2500 (A58214)
2018 DODGE RAM...
2013 Audi A4 Sedan (A55853)
2013 Audi A4 Sedan...
