Servis-Rhino TW72 (1999 model) Gearbox Grease
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #1
MUDONTHETIRES
Gold Member
Northern Louisiana
Mahindra 6065 4WD
Hello all,
The recommended lubricant is NLGI-000 such as Mobil EP023 for the gearbox. Would Lucas 84W-140 work as an alternative?
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #2
I tend to think 85W140 gear oil (even if it is a synthetic) would be a poor substitute for a semi fluid grease such as Mobil’s EP 023 (Mobilux EP 023 is a high performance special-duty semi-fluid greases. This lithium hydroxystearate grease is...)
Thanks so much!
   / Servis-Rhino TW72 (1999 model) Gearbox Grease #6
Not a lube question but perhaps you can help me
I have a Rhino TW72 bought it used
Originally it was owned by a Cemetery (must have been in the foot hills as it has a few scars I would guess from large rocks???
I have a slip clutch on the the drive shaft. It works great on large stuff up to about 4" or a little bigger. But when I cut tall thick grass it cuts it, but leaves some of it a bit tall some after a single pass may be 12 to 16 " high it's usually a strip on I think the right side of the gear drive. Is this typical of this mower? I have a smaller lighter mower 48" which leaves a nicer cut. I was wondering if something is bent on the mower yoke or blades ? Or is this typical for this mower. I do have a flail mower, but I have some old tree branches remnants lying in the fields and don't want to damage the flail. Once I get the fields cleaned of debris, I will use the Flail, Thanks for any help..........
JCB 48Z-1 T4 EXCAVATOR (A52707)
JCB 48Z-1 T4...
CURT MANUFACTRING 1280# SQUARE JACK (A57192)
CURT MANUFACTRING...
2014 Chevrolet Silverado 1500 (A55973)
2014 Chevrolet...
LaneShark LS3 (A56469)
2023 HarbinGer V3 Plus 8KW S/A Towable Light Tower (A55973)
2023 HarbinGer V3...
2011 Chevrolet Impala Sedan (A55853)
2011 Chevrolet...
